주요 콘텐츠로 건너뛰기
Graco Paint Sprayers 17P189 2017 Pump Hose 288623 Replacement
필요한 것
  1. Graco Paint Sprayers 17P189 2017 Pump Hose 288623 Replacement, Pump Hose 288623: 1 단계, 이미지 1/2 Graco Paint Sprayers 17P189 2017 Pump Hose 288623 Replacement, Pump Hose 288623: 1 단계, 이미지 2/2
    • Remove 2 bolts holding the cover on
  2. Graco Paint Sprayers 17P189 2017 Pump Hose 288623 Replacement: 2 단계, 이미지 1/1
    • Remove hose 288623
  3. Graco Paint Sprayers 17P189 2017 Pump Hose 288623 Replacement: 3 단계, 이미지 1/2 Graco Paint Sprayers 17P189 2017 Pump Hose 288623 Replacement: 3 단계, 이미지 2/2
    • Connect bottom hose to pump hose without locking it in all the way. Pulling hard you will pull the top portion of the hose through and feed it all the way over to the right locked in place
  4. Graco Paint Sprayers 17P189 2017 Pump Hose 288623 Replacement: 4 단계, 이미지 1/1
    • With the top hose attached make sure to feed around both ends of the pully and pull bottom hose through and push all the way to the right
결론
다른 13명이 해당 안내서를 완성하였습니다.
Trevor A
회원 가입일: 09/16/21
1,339 평판
안내서 6개 작성하였습니다
댓글 2개
What do i do with the hose plate, throw it away?
JOSEPH - 답글
No, It holds the Hose Coupler in place, not allowing it to wiggle when machine in operation.
MAURICIO - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 17
30일 전: 70
전체 시간: 1,549
