주요 콘텐츠로 건너뛰기
Graco Secure Coverage Nursery Unit Power Jack Replacement
필요한 것
  1. Graco Secure Coverage  Nursery Unit Power Jack Replacement, Nursery Unit Battery: 1 단계, 이미지 3개 중 1개 Graco Secure Coverage  Nursery Unit Power Jack Replacement, Nursery Unit Battery: 1 단계, 이미지 3개 중 2개 Graco Secure Coverage  Nursery Unit Power Jack Replacement, Nursery Unit Battery: 1 단계, 이미지 3개 중 3개
    • Remove the 9mm screw from the battery cover of the nursery unit using a Phillips #1 tip screwdriver.
  2. Graco Secure Coverage  Nursery Unit Power Jack Replacement: 2 단계, 이미지 2개 중 1개 Graco Secure Coverage  Nursery Unit Power Jack Replacement: 2 단계, 이미지 2개 중 2개
    • Using the plastic opening tool, pry and remove the battery cover carefully.
    • Remove the batteries using plastic opening tool.
    • Replace the batteries.
  3. Graco Secure Coverage  Nursery Unit Power Jack Replacement, Nursery Unit Power Jack: 3 단계, 이미지 2개 중 1개 Graco Secure Coverage  Nursery Unit Power Jack Replacement, Nursery Unit Power Jack: 3 단계, 이미지 2개 중 2개
    • Remove the two 9mm Phillips #1 screws from the rare case of the device.
    • Place the screws in a secure place.
  4. Graco Secure Coverage  Nursery Unit Power Jack Replacement: 4 단계, 이미지 1개 중 1개
    • Hold the bottom of the device with one hand and pull down to separate the front and rare cases.
    • While holding the device with one hand, use plastic opening tool to pry the edges of the front case away from the back case.
    • Take your time and apply constant force carefully to avoid breaking any other plastic parts from the device.
  5. Graco Secure Coverage  Nursery Unit Power Jack Replacement: 5 단계, 이미지 2개 중 1개 Graco Secure Coverage  Nursery Unit Power Jack Replacement: 5 단계, 이미지 2개 중 2개
    • Remove all three 7mm Phillips #1 screws from the mother board.
    • Make sure you gently unscrew the screws with moderate force and light pressure to avoid any damages.
  6. Graco Secure Coverage  Nursery Unit Power Jack Replacement: 6 단계, 이미지 2개 중 1개 Graco Secure Coverage  Nursery Unit Power Jack Replacement: 6 단계, 이미지 2개 중 2개
    • Pick up the mother board carefully.
    • Using plastic opening tool, gently pry the power jack plastic part and separate it away from the device case.
    • Apply constant force to avoid breaking the plastic part.
  7. Graco Secure Coverage  Nursery Unit Power Jack Replacement: 7 단계, 이미지 1개 중 1개
    • Solder off the wires from the mother board.
    • There are many pins attached to the mother board, make sure you solder off the proper pins that attached to the power jack wires.
    • Replace the power jack.
결론
작성자
2다른 기여자 명과 함께
Omar Abdullah
회원 가입일: 09/06/15
201 평판
안내서 2개를 작성함
USF Tampa, Team 6-5, Remmell Fall 2015 USF Tampa, Team 6-5, Remmell Fall 2015 회원
USFT-REMMELL-F15S6G5
4 회원들
안내서 8개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 9
전체 시간: 249
