주요 콘텐츠로 건너뛰기
Graco Secure Coverage LED Nursery Unit Replacement
필요한 것
  1. Graco Secure Coverage LED Nursery Unit Replacement, Nursery Unit Battery: 1 단계, 이미지 1/3 Graco Secure Coverage LED Nursery Unit Replacement, Nursery Unit Battery: 1 단계, 이미지 2/3 Graco Secure Coverage LED Nursery Unit Replacement, Nursery Unit Battery: 1 단계, 이미지 3/3
    • Remove the 9mm screw from the battery cover of the nursery unit using a Phillips #1 tip screwdriver.
  2. Graco Secure Coverage LED Nursery Unit Replacement: 2 단계, 이미지 1/2 Graco Secure Coverage LED Nursery Unit Replacement: 2 단계, 이미지 2/2
    • Using the plastic opening tool, pry and remove the battery cover carefully.
    • Remove the batteries using plastic opening tool.
    • Replace the batteries.
  3. Graco Secure Coverage LED Nursery Unit Replacement, LED Nursery Unit: 3 단계, 이미지 1/2 Graco Secure Coverage LED Nursery Unit Replacement, LED Nursery Unit: 3 단계, 이미지 2/2
    • Remove the two 9mm Phillips #1 screws from the rare case of the device.
    • Place the screws in a secure place.
  4. Graco Secure Coverage LED Nursery Unit Replacement: 4 단계, 이미지 1/1
    • Hold the bottom of the device with one hand and pull down to separate the front and rare cases.
    • While holding the device with one hand, use plastic opening tool to pry the edges of the front case away from the back case.
    • Apply constant force carefully to avoid breaking any other plastic parts from the device.
  5. Graco Secure Coverage LED Nursery Unit Replacement: 5 단계, 이미지 1/2 Graco Secure Coverage LED Nursery Unit Replacement: 5 단계, 이미지 2/2
    • Remove all three 7mm Phillips #1 screws from the mother board.
    • Place the screws in secure place.
  6. Graco Secure Coverage LED Nursery Unit Replacement: 6 단계, 이미지 1/3 Graco Secure Coverage LED Nursery Unit Replacement: 6 단계, 이미지 2/3 Graco Secure Coverage LED Nursery Unit Replacement: 6 단계, 이미지 3/3
    • Flip over the motherboard to look at the LED pins that are connected to it.
    • Solder off the LED pin from the motherboard.
    • There are many pins are connect to the motherboard, so make sure that you solder off the LED pin.
    • Replace the LED.
결론
Bryson Wolff
회원 가입일: 08/31/15
237 평판
안내서 2개 작성하였습니다
USF Tampa, Team 6-5, Remmell Fall 2015 USF Tampa, Team 6-5, Remmell Fall 2015 회원
USFT-REMMELL-F15S6G5
4 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 7
전체 시간: 140
