주요 콘텐츠로 건너뛰기
Graco Secure Coverage LED Parent Unit Replacement
필요한 것
  1. Graco Secure Coverage LED Parent Unit Replacement, Parent Unit Battery: 1 단계, 이미지 1/3 Graco Secure Coverage LED Parent Unit Replacement, Parent Unit Battery: 1 단계, 이미지 2/3 Graco Secure Coverage LED Parent Unit Replacement, Parent Unit Battery: 1 단계, 이미지 3/3
    • Using plastic opening tool, pry and remove the battery lid.
  2. Graco Secure Coverage LED Parent Unit Replacement: 2 단계, 이미지 1/1
    • Remove the battery by holding the device with one hand and pulling the battery out with other hand carefully.
    • Make sure that you disconnect the battery's wire before you remove the battery.
  3. Graco Secure Coverage LED Parent Unit Replacement, LED Parent Unit: 3 단계, 이미지 1/2 Graco Secure Coverage LED Parent Unit Replacement, LED Parent Unit: 3 단계, 이미지 2/2
    • There are two screws on the rare case of the device. For the one shown in blue marker requires either an extended screwdriver or putting on a little pressure on a regular screwdriver.
    • Remove the two 9mm Phillips #1 screws from the rare case of the device.
    • If you cannot remove the screw with low pressure, do not use high pressure to remove it. It may cause a damage on the device case. Use an extended screwdriver instead.
  4. Graco Secure Coverage LED Parent Unit Replacement: 4 단계, 이미지 1/2 Graco Secure Coverage LED Parent Unit Replacement: 4 단계, 이미지 2/2
    • Using opening plastic tool, pry the two grey cases from both sides of the device.
    • Take your time and apply constant force to avoid breaking or damaging any other plastic parts.
    • While pry off the grey cases, hold the device with your other hand to remove the cases
  5. Graco Secure Coverage LED Parent Unit Replacement: 5 단계, 이미지 1/1
    • Pry the edges of the device to separate the front and rare cases.
    • While prying the edges, hold the device with one hand to pull out each case a part.
    • Make sure you use a constant force, and the pushbuttons are pried off completely.
  6. Graco Secure Coverage LED Parent Unit Replacement: 6 단계, 이미지 1/2 Graco Secure Coverage LED Parent Unit Replacement: 6 단계, 이미지 2/2
    • Remove the 7mm Phillips #1 screw from the mother board.
    • Place the screw in a secure place.
  7. Graco Secure Coverage LED Parent Unit Replacement: 7 단계, 이미지 1/2 Graco Secure Coverage LED Parent Unit Replacement: 7 단계, 이미지 2/2
    • Flip over the motherboard.
    • Solder off LED from motherboard.
    • There are many pins attached to the motherboard, make sure you solder off the proper pins that attached to the LED's.
    • Replace the LED's
결론
Bryson Wolff
회원 가입일: 08/31/15
237 평판
안내서 2개 작성하였습니다
USF Tampa, Team 6-5, Remmell Fall 2015 USF Tampa, Team 6-5, Remmell Fall 2015 회원
USFT-REMMELL-F15S6G5
4 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 5
전체 시간: 89
