주요 콘텐츠로 건너뛰기
Graco Secure Coverage Nursery Unit Battery Replacement
필요한 것
  1. Graco Secure Coverage Nursery Unit Battery Replacement, Nursery Unit Battery: 1 단계, 이미지 1/3 Graco Secure Coverage Nursery Unit Battery Replacement, Nursery Unit Battery: 1 단계, 이미지 2/3 Graco Secure Coverage Nursery Unit Battery Replacement, Nursery Unit Battery: 1 단계, 이미지 3/3
    • Remove the 9mm screw from the battery cover of the nursery unit using a Phillips #1 tip screwdriver.
  2. Graco Secure Coverage Nursery Unit Battery Replacement: 2 단계, 이미지 1/2 Graco Secure Coverage Nursery Unit Battery Replacement: 2 단계, 이미지 2/2
    • Using the plastic opening tool, pry and remove the battery cover carefully.
    • Remove the batteries using plastic opening tool.
    • Replace the batteries.
결론
Rogelio Morales
회원 가입일: 08/31/15
201 평판
안내서 2개 작성하였습니다
USF Tampa, Team 6-5, Remmell Fall 2015 USF Tampa, Team 6-5, Remmell Fall 2015 회원
USFT-REMMELL-F15S6G5
4 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 6
전체 시간: 181
