주요 콘텐츠로 건너뛰기
Graco Secure Coverage Parent Unit Battery Replacement
필요한 것
  1. Graco Secure Coverage Parent Unit Battery Replacement, Parent Unit Battery: 1 단계, 이미지 1/3 Graco Secure Coverage Parent Unit Battery Replacement, Parent Unit Battery: 1 단계, 이미지 2/3 Graco Secure Coverage Parent Unit Battery Replacement, Parent Unit Battery: 1 단계, 이미지 3/3
    • Using plastic opening tool, pry and remove the battery lid.
  2. Graco Secure Coverage Parent Unit Battery Replacement: 2 단계, 이미지 1/1
    • Remove the battery by holding the device with one hand and pulling the battery out with other hand carefully.
    • Make sure that you disconnect the battery's wire before you remove the battery.
결론
Rogelio Morales
회원 가입일: 08/31/15
201 평판
안내서 2개 작성하였습니다
USF Tampa, Team 6-5, Remmell Fall 2015 USF Tampa, Team 6-5, Remmell Fall 2015 회원
USFT-REMMELL-F15S6G5
4 회원들
안내서 8개 작성하였습니다
댓글 한 개
Would anyone happen to know the type of battery needed for the replacement on this baby monitor?
Shaun Barnes (WheelchairShaun) - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 8
전체 시간: 705
