주요 콘텐츠로 건너뛰기
Graco Secure Coverage Parent Unit Battery Replacement
필요한 것
  1. Graco Secure Coverage Parent Unit Battery Replacement, Parent Unit Battery: 1 단계, 이미지 3개 중 1개 Graco Secure Coverage Parent Unit Battery Replacement, Parent Unit Battery: 1 단계, 이미지 3개 중 2개 Graco Secure Coverage Parent Unit Battery Replacement, Parent Unit Battery: 1 단계, 이미지 3개 중 3개
    • Using plastic opening tool, pry and remove the battery lid.
  2. Graco Secure Coverage Parent Unit Battery Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the battery by holding the device with one hand and pulling the battery out with other hand carefully.
    • Make sure that you disconnect the battery's wire before you remove the battery.
결론
작성자
6다른 기여자 명과 함께
Rogelio Morales
회원 가입일: 08/31/15
201 평판
안내서 2개를 작성함
USF Tampa, Team 6-5, Remmell Fall 2015 USF Tampa, Team 6-5, Remmell Fall 2015 회원
USFT-REMMELL-F15S6G5
4 회원들
안내서 8개를 작성함
1가이드 댓글
Would anyone happen to know the type of battery needed for the replacement on this baby monitor?
Shaun Barnes (WheelchairShaun) - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 15
전체 시간: 899
