주요 콘텐츠로 건너뛰기
Graco Snugrider Elite Cup-holder Replacement
  1. Graco Snugrider Elite Cup-holder Replacement, Cup-holder: 1 단계, 이미지 1/2 Graco Snugrider Elite Cup-holder Replacement, Cup-holder: 1 단계, 이미지 2/2
    • Pull the plastic lock pieces that secure the cup-holder on both sides of the stroller.
  2. Graco Snugrider Elite Cup-holder Replacement: 2 단계, 이미지 1/1
    • Slide the plastic lock sticks (attached to the cup-holder) down and out of the lock on both sides.
  3. Graco Snugrider Elite Cup-holder Replacement: 3 단계, 이미지 1/3 Graco Snugrider Elite Cup-holder Replacement: 3 단계, 이미지 2/3 Graco Snugrider Elite Cup-holder Replacement: 3 단계, 이미지 3/3
    • At this point, it is easier to lay the stroller down so that the bottom of the cup-holder faces up.
    • Locate the black tabs on the underside of the cup-holder.
    • Push the tabs towards the center of the cup-holder to detach it and push the cup-holder towards the top of the stroller to take it off.
결론
Nick Spencer
회원 가입일: 10/01/15
107 평판
안내서 1개 작성함
Cal Poly, Team 11-3, Forte Fall 2015 Cal Poly, Team 11-3, Forte Fall 2015 회원
CPSU-FORTE-F15S11G3
4 회원들
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 10
30일 전: 24
전체 시간: 3,003
