주요 콘텐츠로 건너뛰기
GravityLight Dial Replacement
필요한 것
  1. GravityLight Dial Replacement, Removing the Front Panel: 1 단계, 이미지 2개 중 1개 GravityLight Dial Replacement, Removing the Front Panel: 1 단계, 이미지 2개 중 2개
    • Flip the GravityLight on its back and place it on a sturdy surface.
    • Unscrew the three 2cm Phillips #00 screws on the back of the GravityLight’s body.
  2. GravityLight Dial Replacement, Opening the Device Housing: 2 단계, 이미지 1개 중 1개
    • Some of the internal pieces may loosen or fall out during disassembly.
    • Firmly grasp both parts of the GravityLight body and pull them apart.
  3. GravityLight Dial Replacement, Isolating the Front Panel: 3 단계, 이미지 1개 중 1개
    • Take the thinner of the two parts, the front piece, and place it face down on a sturdy surface.
    • Ignore the back piece for now, but keep it in a safe place.
  4. GravityLight Dial Replacement, Popping the Dial out: 4 단계, 이미지 2개 중 1개 GravityLight Dial Replacement, Popping the Dial out: 4 단계, 이미지 2개 중 2개
    • Use two hands to push the dial tabs inward, towards the center of the dial.
    • Push the tabs downward and through to the other side of the casing.
    • Flip the front panel over.
  5. GravityLight Dial Replacement, Removing the Dial: 5 단계, 이미지 1개 중 1개
    • Fully remove the dial by pulling it out from the front.
결론
작성자
4다른 기여자 명과 함께
Michallynn Hoffman
회원 가입일: 09/26/14
317 평판
안내서 3개를 작성함
Cal Poly, Team 12-2, Forte Fall 2014 Cal Poly, Team 12-2, Forte Fall 2014 회원
CPSU-FORTE-F14S12G2
5 회원들
안내서 7개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 7
지난 30일: 18
전체 시간: 866
