주요 콘텐츠로 건너뛰기
GravityLight Internal Gears Replacement
필요한 것
  1. GravityLight Internal Gears Replacement, Removing the Front Panel: 1 단계, 이미지 1/2 GravityLight Internal Gears Replacement, Removing the Front Panel: 1 단계, 이미지 2/2
    • Flip the GravityLight on its back and place it on a sturdy surface.
    • Unscrew the three 2cm Phillips #00 screws on the back of the GravityLight’s body.
  2. GravityLight Internal Gears Replacement, Opening the Device Housing: 2 단계, 이미지 1/1
    • Some of the internal pieces may loosen or fall out during disassembly.
    • Firmly grasp both parts of the GravityLight body and pull them apart.
  3. GravityLight Internal Gears Replacement, Isolating the Back Panel: 3 단계, 이미지 1/1
    • Take the thicker of the two parts, the back piece, and place it face down on a sturdy surface.
  4. GravityLight Internal Gears Replacement, Removing the Back Panel Screws: 4 단계, 이미지 1/1
    • Place the back panel, the larger of the two pieces, on a sturdy surface with its back down.
    • Unscrew the two 2cm Phillips 00 screws on the inside of the back panel.
  5. GravityLight Internal Gears Replacement, Removing the LED Housing: 5 단계, 이미지 1/1
    • Watch out for the wires! Keep them attached for this entire guide, or the GravityLight will not work!
    • Gently lift off the LED housing (the white disk).
    • Set the LED housing on the table next to the body of the device.
  6. GravityLight Internal Gears Replacement, Removing White Frame and Gear: 6 단계, 이미지 1/1
    • Lift off the white piece with four arms.
    • Lift off the black-rimmed gear.
    • Set both pieces aside in a safe place.
  7. GravityLight Internal Gears Replacement, Removing Internal Gears: 7 단계, 이미지 1/2 GravityLight Internal Gears Replacement, Removing Internal Gears: 7 단계, 이미지 2/2
    • Lift off the three 3.5cm diameter gears.
    • Replace any stripped gears.
결론
Michallynn Hoffman
회원 가입일: 09/26/14
317 평판
안내서 3개 작성하였습니다
Cal Poly, Team 12-2, Forte Fall 2014 Cal Poly, Team 12-2, Forte Fall 2014 회원
CPSU-FORTE-F14S12G2
5 회원들
안내서 7개 작성하였습니다
댓글 한 개
Where can we find the replacement gears?
fb - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 4
전체 시간: 3,057
