주요 콘텐츠로 건너뛰기
GravityLight Mounting Post Replacement and Spring Replacement
필요한 것
  1. GravityLight Mounting Post Replacement and Spring Replacement, Removing the Front Panel: 1 단계, 이미지 2개 중 1개 GravityLight Mounting Post Replacement and Spring Replacement, Removing the Front Panel: 1 단계, 이미지 2개 중 2개
    • Flip the GravityLight on its back and place it on a sturdy surface.
    • Unscrew the three 2cm Phillips #00 screws on the back of the GravityLight’s body.
  2. GravityLight Mounting Post Replacement and Spring Replacement, Opening the Device Housing: 2 단계, 이미지 1개 중 1개
    • Some of the internal pieces may loosen or fall out during disassembly.
    • Firmly grasp both parts of the GravityLight body and pull them apart.
  3. GravityLight Mounting Post Replacement and Spring Replacement, Removing the Back Panel Screws: 3 단계, 이미지 1개 중 1개
    • Place the back panel, the larger of the two pieces, on a sturdy surface with its back down.
    • Unscrew the two 2cm Phillips 00 screws on the inside of the back panel.
  4. GravityLight Mounting Post Replacement and Spring Replacement, Separating the Back Panel Housing: 4 단계, 이미지 3개 중 1개 GravityLight Mounting Post Replacement and Spring Replacement, Separating the Back Panel Housing: 4 단계, 이미지 3개 중 2개 GravityLight Mounting Post Replacement and Spring Replacement, Separating the Back Panel Housing: 4 단계, 이미지 3개 중 3개
    • Firmly grasp both parts of the back panel and pull them apart.
  5. GravityLight Mounting Post Replacement and Spring Replacement, Orienting the Middle Section: 5 단계, 이미지 1개 중 1개
    • Place the middle section on a sturdy surface.
    • Move any wires in front of the mounting post.
  6. GravityLight Mounting Post Replacement and Spring Replacement, Removing the Mounting Post from the Middle Section.: 6 단계, 이미지 2개 중 1개 GravityLight Mounting Post Replacement and Spring Replacement, Removing the Mounting Post from the Middle Section.: 6 단계, 이미지 2개 중 2개
    • Push down on the spring.
    • The spring is very stiff. Compressing the spring requires a moderate amount of force.
    • Push the spring and the mounting post away from the middle section and remove them from the pocket.
  7. GravityLight Mounting Post Replacement and Spring Replacement, Separate Mounting Post and Spring: 7 단계, 이미지 2개 중 1개 GravityLight Mounting Post Replacement and Spring Replacement, Separate Mounting Post and Spring: 7 단계, 이미지 2개 중 2개
    • Pull the mounting post out of the inside of the spring
결론
작성자
2다른 기여자 명과 함께
Jamie Forslin
회원 가입일: 09/26/14
143 평판
안내서 1개를 작성함
Cal Poly, Team 12-2, Forte Fall 2014 Cal Poly, Team 12-2, Forte Fall 2014 회원
CPSU-FORTE-F14S12G2
5 회원들
안내서 7개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 2
지난 30일: 9
전체 시간: 814
