주요 콘텐츠로 건너뛰기
Greist Buttonholer Button Template Replacement
  1. Greist Buttonholer Button Template Replacement, Preparing the Buttonholer: 1 단계, 이미지 2개 중 1개 Greist Buttonholer Button Template Replacement, Preparing the Buttonholer: 1 단계, 이미지 2개 중 2개
    • Turn the adjusting knob to the right until the cloth clamp is extended as far as it can go.
  2. Greist Buttonholer Button Template Replacement, Open the Retainer Plate: 2 단계, 이미지 2개 중 1개 Greist Buttonholer Button Template Replacement, Open the Retainer Plate: 2 단계, 이미지 2개 중 2개
    • Located on the bottom, pull the lip of the retainer plate away from The Buttonholer, and then open the plate.
  3. Greist Buttonholer Button Template Replacement, Remove the Template: 3 단계, 이미지 2개 중 1개 Greist Buttonholer Button Template Replacement, Remove the Template: 3 단계, 이미지 2개 중 2개
    • Since the clamp is extended as far as it can go, the template should come out easily.
  4. Greist Buttonholer Button Template Replacement, Choose a New Template: 4 단계, 이미지 2개 중 1개 Greist Buttonholer Button Template Replacement, Choose a New Template: 4 단계, 이미지 2개 중 2개
    • 4 additional templates are included with The Buttonholer. Each template creates a different size button hole.
    • If you are unsure which template is right for your project, check the back of each template for the diameter of the holes that they make.
  5. Greist Buttonholer Button Template Replacement, Insert the New Template: 5 단계, 이미지 2개 중 1개 Greist Buttonholer Button Template Replacement, Insert the New Template: 5 단계, 이미지 2개 중 2개
    • Place the template into The Buttonholer, and then close the retainer plate.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Michael Sykes
회원 가입일: 10/06/14
552 평판
안내서 5개를 작성함
USF Tampa, Team 3-6, Brown Fall 2014 USF Tampa, Team 3-6, Brown Fall 2014 회원
USFT-BROWN-F14S3G6
5 회원들
안내서 8개를 작성함
1가이드 댓글
I had to use the reduction knob so the fabric holder was not fully extended to open the plate. So play with it. Better lighting on the unit once it was upside down and dark would have been helpful. But I did manage with this and the booklet. thank you.
Marcy - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 2
전체 시간: 518
