이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Turn the adjusting knob to the right until the cloth clamp is extended as far as it can go.
Located on the bottom, pull the lip of the retainer plate away from The Buttonholer, and then open the plate.
Since the clamp is extended as far as it can go, the template should come out easily.
4 additional templates are included with The Buttonholer. Each template creates a different size button hole.
If you are unsure which template is right for your project, check the back of each template for the diameter of the holes that they make.
Place the template into The Buttonholer, and then close the retainer plate.
다른 한 분이 해당 안내서를 완성하였습니다.
