주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
소개
In order to properly maintain and repair the Buttonholer, you will need to know how to remove the cover.
부품
지정된 부품이 없습니다.
  1. Press down on the adjusting knob, and turn it to the left until the knob is unscrewed. Press down on the adjusting knob, and turn it to the left until the knob is unscrewed.
    • Press down on the adjusting knob, and turn it to the left until the knob is unscrewed.
  2. SKIP THE UPGRADE
    Save by fixing with an all-in-one kit.
    Shop iPhone Fix Kits
    SKIP THE UPGRADE
  3. Using the phillips screwdriver, unscrew the cover screw.
    • Using the phillips screwdriver, unscrew the cover screw.
  4. You can now remove the cover from The Buttonholer
    • You can now remove the cover from The Buttonholer
결론
Michael Sykes
회원 가입일: 2014년 10월 06일
552 평판
안내서 5개 작성하였습니다
USF Tampa, Team 3-6, Brown Fall 2014 USF Tampa, Team 3-6, Brown Fall 2014 회원
USFT-BROWN-F14S3G6
5 회원들
안내서 5개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 100
