이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
If the fork arm in The Buttonholer is not moving properly while being operated, chance are you need to replace the spring holding the arm.
필요한 것
Unscrew the screw located underneath fork arm using a Flathead screwdriver.
Raise the fork arm so that it is parallel with the upper hook.
Turn the lower hook towards you from the bottom, and remove.
거의 끝나갑니다!
결론
