메인 콘텐츠로 스킵하기
소개
This guide will teach the user how to install the right side panel and align the buttons correctly. It will also focus on the restoration of functionality of the device and show the proper placement of the buttons to restore the device to its retail form.
부품
지정된 부품이 없습니다.
  1. Use the plastic opening tool.
    • Use the plastic opening tool.
    • Lodge the tip into the corner of the device; Applying pressure upward, allowing the panel to be released.
  2. The side panel can now be detached using your fingers. The buttons can be dislodged by turning the panel over and shaking it, if necessary. The buttons can be dislodged by turning the panel over and shaking it, if necessary.
    • The side panel can now be detached using your fingers.
    • The buttons can be dislodged by turning the panel over and shaking it, if necessary.
  3. 맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
    맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
  4. Ensure that the elevated grating is on the left side of the button, as seen in the first posted image.
    • Ensure that the elevated grating is on the left side of the button, as seen in the first posted image.
    • Insert the button with the sound diagrams to the top section of the panel.
  5. Ensure that the elevated grating is on the left side of the button, as seen in the posted image.
    • Ensure that the elevated grating is on the left side of the button, as seen in the posted image.
    • Insert the button with the two arrows to the bottom section of the panel.
  6. Be careful with handling the panel during placement. Utilize gravity to keep the buttons from falling out.
    • Be careful with handling the panel during placement. Utilize gravity to keep the buttons from falling out.
    • Using your fingers, carefully click in the bottom end of the panel, followed by the top end of the panel.
  7. Apply pressure to both side panels simultaneously to ensure the device has restored original stability. Apply pressure to both side panels simultaneously to ensure the device has restored original stability.
    • Apply pressure to both side panels simultaneously to ensure the device has restored original stability.
결론
After installation, the device should look similar to that which is depicted in the cover image (top right of page).
Alexander
회원 가입일: 2012년 03월 09일
101 평판
안내서 9개 작성하였습니다
Clemson, Team 15-3, Benson Spring 2012 Clemson, Team 15-3, Benson Spring 2012 회원
CLEM-BENSON-S12S15G3
3 회원들
안내서 9개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 2
전체 시간: 845
