주요 콘텐츠로 건너뛰기
Grip Tape Application
필요한 것
  1. Grip Tape Application, Grip Tape Application: 1 단계, 이미지 1개 중 1개
    • Peel off the paper backing from the sheet of grip tape.
    • Make sure you do not fold or wrinkle the grip tape.
  2. Grip Tape Application: 2 단계, 이미지 1개 중 1개
    • Center the sheet of grip tape evenly over the top of the skateboard deck.
  3. Grip Tape Application: 3 단계, 이미지 2개 중 1개 Grip Tape Application: 3 단계, 이미지 2개 중 2개
    • Starting from the very middle and moving outward, firmly press down on the grip tape while smoothing out any air bubbles that start to form.
  4. Grip Tape Application: 4 단계, 이미지 2개 중 1개 Grip Tape Application: 4 단계, 이미지 2개 중 2개
    • Use a screwdriver to scrape along the edges of the skateboard. This will remove some of the grip around the edges making the trimming process easier on you and your equipment.
    • You can use the utility knife to cut a perpendicular line in the excess grip tape if it is resisting the screwdriver too much.
  5. Grip Tape Application: 5 단계, 이미지 3개 중 1개 Grip Tape Application: 5 단계, 이미지 3개 중 2개 Grip Tape Application: 5 단계, 이미지 3개 중 3개
    • Use a utility knife to begin cutting around the edge of your skateboard to remove excess grip tape.
    • Angle your knife towards the inside of the skateboard to make it easier to cut a straight line.
    • Be careful when using the utility knife and always keep it pointed away from yourself and others.
  6. Grip Tape Application: 6 단계, 이미지 1개 중 1개
    • Once you have removed all of the excess grip tape, you can use the scraps to sand the edges of your cut to smooth out any small inconsistencies.
    • Use caution when sanding as the grip tape can become heated.
  7. Grip Tape Application: 7 단계, 이미지 1개 중 1개
    • If air bubbles persist, gently use a utility knife to poke a small hole in the grip tape at the center of the bubble and press out the air.
  8. Grip Tape Application: 8 단계, 이미지 2개 중 1개 Grip Tape Application: 8 단계, 이미지 2개 중 2개
    • After you have finished applying your grip tape, you can use a small screwdriver to poke holes where your truck hardware will be installed.
결론
The next logical step in the assembly of a skateboard is to install skateboard trucks, please reference the Truck Installation guide.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Jared Stine
회원 가입일: 10/05/12
800 평판
안내서 3개를 작성함
Cal Poly, Team 6-32, Regan Fall 2012 Cal Poly, Team 6-32, Regan Fall 2012 회원
CPSU-REGAN-F12S6G32
5 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 19
전체 시간: 8,182
