주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Guitar String Replacement
필요한 것
  1. Guitar String Replacement, Loosen the tuning pegs: 1 단계, 이미지 1개 중 1개
    • Turn the tuning pegs counter clock-wise to loosen all of the guitar strings and release the tension.
    댓글 쓰기
  2. Guitar String Replacement, Remove old guitar strings: 2 단계, 이미지 1개 중 1개
    • Cutting a string under tension could cause injury. Ensure that all strings are loose before attempting the next step.
    • Once the strings are loose and have no tension, cut the strings with a handheld wire cutter.
    • Cut the knots near the tuning pegs and bridge as needed. Then, pull the strings to remove them.
    댓글 쓰기
  3. Guitar String Replacement, Thread strings through the bridge: 3 단계, 이미지 3개 중 1개 Guitar String Replacement, Thread strings through the bridge: 3 단계, 이미지 3개 중 2개 Guitar String Replacement, Thread strings through the bridge: 3 단계, 이미지 3개 중 3개
    • The first three strings (low E, A, and D), have thick and springy ends; the three thinnest strings (G, B, and high E), do not have thick or springy ends. You may use either set of strings.
    • Insert the thick end of the string into the top of the bridge and thread it through until about 3 to 4 inches of the string stick out of the bottom.
    • Wrap the short end of the string around the long end of the string, creating a loop.
    • Pass the short end of the string through the loop (2 or 3 times for thick strings, 3 or 4 times for thin strings). Make sure the final pass leaves the string underneath the bridge.
    • Pull both ends of the string until the knot is tight.
    댓글 쓰기
  4. Guitar String Replacement, Knot the low E, G, and B strings: 4 단계, 이미지 3개 중 1개 Guitar String Replacement, Knot the low E, G, and B strings: 4 단계, 이미지 3개 중 2개 Guitar String Replacement, Knot the low E, G, and B strings: 4 단계, 이미지 3개 중 3개
    • This knot will be used for only the low E, G, and B strings.
    • Insert the springy end of the string into the hole in the tuning peg.
    • Pull the springy end over the tuning peg and to the left side.
    • Bring the springy end to the right side by passing it under the string, creating a loop.
    • Push the springy end through the loop, and then pull both ends until the knot is tight. You may have to press the knot with your finger tighten it completely.
    댓글 쓰기
  5. Guitar String Replacement, Knot the A, D, and high E strings: 5 단계, 이미지 3개 중 1개 Guitar String Replacement, Knot the A, D, and high E strings: 5 단계, 이미지 3개 중 2개 Guitar String Replacement, Knot the A, D, and high E strings: 5 단계, 이미지 3개 중 3개
    • Repeat step 4 (outlined below) for only the strings A, D, and high E .
    • Insert the end of the string into the hole in the tuning peg.
    • Pull the end over the tuning peg to the right side.
    • Bring the end of the string to the left side by passing it under the string, creating a loop.
    • Push the end through the loop and then pull both ends until the knot is tight. You may have to press and hold the knot with your finger to tighten completely.
    댓글 쓰기
  6. Guitar String Replacement, Tighten the new strings: 6 단계, 이미지 3개 중 1개 Guitar String Replacement, Tighten the new strings: 6 단계, 이미지 3개 중 2개 Guitar String Replacement, Tighten the new strings: 6 단계, 이미지 3개 중 3개
    • Turn the tuning knob in a clock-wise motion to tighten the string until the string makes a clear sound when plucked.
    • As you tighten the string, be sure to hold the string with your free hand until the string stays tight on its own. This will keep the knot from loosening.
    • As the string winds around the tuning peg, make sure that the string passes over the loose end from the knot at least once. This will prevent "slipping" (detuning) during tuning and will help keep the knot tight.
    댓글 쓰기
  7. Guitar String Replacement, Check your work before tuning: 7 단계, 이미지 1개 중 1개
    • Before moving on, compare your work to the image provided. If the head of your guitar does not resemble the guitar in the image, go back to steps 3 and 4.
    • The E strings should be facing outwards (or "away from the body") and the rest of the strings should be facing inwards (or "toward the body").
    • Check that strings are properly set in the notches of the nut of the guitar. The "nut" is the white bar just below the head of the guitar.
    • You are ready to tune your guitar! Classical guitar strings may "slip" or detune. It may take 4 or more rounds of tuning before the new strings stop slipping.
    댓글 쓰기
  8. Guitar String Replacement, Clip the loose ends: 8 단계, 이미지 3개 중 1개 Guitar String Replacement, Clip the loose ends: 8 단계, 이미지 3개 중 2개 Guitar String Replacement, Clip the loose ends: 8 단계, 이미지 3개 중 3개
    • Once you have tuned your guitar, remove the loose ends of the strings from the head and bridge of the guitar with your handheld wire cutter.
    • Do not completely remove the loose ends. Cutting the end too close to the tuning peg or the bridge may cause the string to slip out of position later. Leave at least a half inch piece in place.
    댓글 쓰기
결론
Your new strings are now in place!
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Nicholas Mullins
회원 가입일: 01/19/16
129 평판
안내서 1개를 작성함
Oakland University, Team 6-1, Walwema Winter 2016 Oakland University, Team 6-1, Walwema Winter 2016 회원
OAK-WALWEMA-W16S6G1
10 회원들
안내서 34개를 작성함
1가이드 댓글
what do I pay? very good site haven't played in a while usually at church
davenport - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 27
지난 30일: 120
전체 시간: 10,590
