주요 콘텐츠로 건너뛰기
HASEE Z6-SL7D1 RAM Replacement
필요한 것
  1. HASEE Z6-SL7D1 RAM Replacement, RAM: 1 단계, 이미지 2개 중 1개 HASEE Z6-SL7D1 RAM Replacement, RAM: 1 단계, 이미지 2개 중 2개
    • Flip your laptop over so the bottom is facing up and set it on a flat surface.
    • Use a Phillips #0 screwdriver to remove the two 6 mm screws that secure the battery.
  2. HASEE Z6-SL7D1 RAM Replacement: 2 단계, 이미지 2개 중 1개 HASEE Z6-SL7D1 RAM Replacement: 2 단계, 이미지 2개 중 2개
    • Gently lift the battery from the laptop.
  3. HASEE Z6-SL7D1 RAM Replacement: 3 단계, 이미지 2개 중 1개 HASEE Z6-SL7D1 RAM Replacement: 3 단계, 이미지 2개 중 2개
    • Use a Phillips #0 screwdriver to remove fourteen 6 mm screws from the back panel.
  4. HASEE Z6-SL7D1 RAM Replacement: 4 단계, 이미지 2개 중 1개 HASEE Z6-SL7D1 RAM Replacement: 4 단계, 이미지 2개 중 2개
    • If your laptop is equipped with an optical drive, carefully slide it out.
    • Alternatively, if the optical drive bay houses a hard drive tray, remove the tray by unscrewing any securing screws and gently pulling it out.
  5. HASEE Z6-SL7D1 RAM Replacement: 5 단계, 이미지 2개 중 1개 HASEE Z6-SL7D1 RAM Replacement: 5 단계, 이미지 2개 중 2개
    • Carefully slide a plastic spudger or opening tool along the edges of the back panel.
    • Gradually lift the panel away from the laptop chassis, ensuring not to force it and risking damage to internal components.
  6. HASEE Z6-SL7D1 RAM Replacement: 6 단계, 이미지 3개 중 1개 HASEE Z6-SL7D1 RAM Replacement: 6 단계, 이미지 3개 중 2개 HASEE Z6-SL7D1 RAM Replacement: 6 단계, 이미지 3개 중 3개
    • Use your fingers or a spudger to gently press the clips on the sides of the SO-DIMM slots outward to release the memory modules.
    • The RAM sticks will pop out at about a 45-degree angle.
    • Once the RAM sticks disengage, carefully slide them out of the slot at the same angle.
  7. HASEE Z6-SL7D1 RAM Replacement: 7 단계, 이미지 2개 중 1개 HASEE Z6-SL7D1 RAM Replacement: 7 단계, 이미지 2개 중 2개
    • When installing new memory sticks, align them with the SO-DIMM slots at the same angle and gently press them downward.
    • You will hear a click, indicating that it is securely in place.
  8. HASEE Z6-SL7D1 RAM Replacement: 8 단계, 이미지 2개 중 1개 HASEE Z6-SL7D1 RAM Replacement: 8 단계, 이미지 2개 중 2개
    • Replace the back case.
    • Insert the optical drive back into its designated slot.
    • Replace the battery.
    • Use a Phillips #0 screwdriver to secure the fourteen 6 mm screws on the back case.
    • Use a Phillips #0 screwdriver to replace the two 6 mm screws that secure the battery.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Jiayi Liu
회원 가입일: 02/11/24
175 평판
안내서 1개를 작성함
York University, Team M-7, Allen Winter 2024 York University, Team M-7, Allen Winter 2024 회원
YORK-ALLEN-W24SMG7
3 회원들
안내서 2개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 18
지난 7일: 194
지난 30일: 363
전체 시간: 538
