주요 콘텐츠로 건너뛰기
HKC P771A Camera Replacement
필요한 것
  1. HKC P771A Camera Replacement, Camera: 1 단계, 이미지 1/3 HKC P771A Camera Replacement, Camera: 1 단계, 이미지 2/3 HKC P771A Camera Replacement, Camera: 1 단계, 이미지 3/3
    • Remove back of tablet using the plastic opening tool
    • Slide the opening tool between the back of the tablet and the digitizer
    • Lift along the edges until the back of the tablet and the digitizer are separated
  2. HKC P771A Camera Replacement: 2 단계, 이미지 1/2 HKC P771A Camera Replacement: 2 단계, 이미지 2/2
    • Remove yellow tape around the edges of the battery
    • The battery is located on the right side of the tablet when the screen is facing downwards and the camera is on top
  3. HKC P771A Camera Replacement: 3 단계, 이미지 1/3 HKC P771A Camera Replacement: 3 단계, 이미지 2/3 HKC P771A Camera Replacement: 3 단계, 이미지 3/3
    • Pry battery away from the back of the tablet until the battery is completely separated from the adhesive
  4. HKC P771A Camera Replacement: 4 단계, 이미지 1/1
    • Remove yellow tape that is securing the camera wires
  5. HKC P771A Camera Replacement: 5 단계, 이미지 1/2 HKC P771A Camera Replacement: 5 단계, 이미지 2/2
    • Remove silver foil from the back of the camera using the blue opening tool
  6. HKC P771A Camera Replacement: 6 단계, 이미지 1/1
    • Lift the bronze, L-shaped ribbon
    • The camera is attached to the end of this ribbon so it will move with it
  7. HKC P771A Camera Replacement: 7 단계, 이미지 1/1
    • Flip up the black bar located on the motherboard
    • The black bar is to the left of the camera, where the ribbon is attached to the motherboard
  8. HKC P771A Camera Replacement: 8 단계, 이미지 1/1
    • Remove the bronze, L-shaped ribbon from inside the black bar
  9. HKC P771A Camera Replacement: 9 단계, 이미지 1/1
    • Your camera is now removed from the tablet
결론
Sara Hill
회원 가입일: 09/30/15
101 평판
안내서 2개 작성하였습니다
Ohio State, Team 2-3, Garvin Fall 2015 Ohio State, Team 2-3, Garvin Fall 2015 회원
OSU-GARVIN-F15S2G3
4 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 170
