주요 콘텐츠로 건너뛰기
HKC P771A Digitizer Replacement
필요한 것
  1. HKC P771A Digitizer Replacement, Digitizer: 1 단계, 이미지 1/2 HKC P771A Digitizer Replacement, Digitizer: 1 단계, 이미지 2/2
    • Remove back of tablet using the plastic opening tool
    • Slide the opening tool between the back of the tablet and the digitizer
    • Lift along the edges until the back of the tablet and the digitizer are separated
  2. HKC P771A Digitizer Replacement: 2 단계, 이미지 1/2 HKC P771A Digitizer Replacement: 2 단계, 이미지 2/2
    • Remove 4 screws located on the red motherboard
    • The red motherboard will be loose, but does not need to come completely unattached
  3. HKC P771A Digitizer Replacement: 3 단계, 이미지 1/1
    • Remove 7 screws located around the edges of the tablet
    • 5 screws are visible around the edges of the device and 2 screws are located underneath the red motherboard
  4. HKC P771A Digitizer Replacement: 4 단계, 이미지 1/1
    • Lift digitizer from the screen
    • After removing all of the screws, the screen should easily separate from the digitizer
  5. HKC P771A Digitizer Replacement: 5 단계, 이미지 1/1
    • Now you can replace the old digitizer with a new one
결론
Sara Hill
회원 가입일: 09/30/15
101 평판
안내서 2개 작성하였습니다
Ohio State, Team 2-3, Garvin Fall 2015 Ohio State, Team 2-3, Garvin Fall 2015 회원
OSU-GARVIN-F15S2G3
4 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 5
전체 시간: 256
