소개
The camera can be replaced, by disconnecting it from the motherboard. This is a fairly simple repair.
필요한 것
Insert the flat end of the spudger into the side of the device
This will create a gap between the device and screen housing.
Insert the plastic opening tool into this gap and move it along this gap.
The screen housing and device will now be separated.
Use the tweezers to pull out the black pins (circled in red).
Use the tweezers to remove the camera band from the motherboard.
거의 끝나갑니다!
결론
