주요 콘텐츠로 건너뛰기
HKC P774A Digitizer Replacement
필요한 것
  1. HKC P774A Digitizer Replacement, Digitizer: 1 단계, 이미지 1/3 HKC P774A Digitizer Replacement, Digitizer: 1 단계, 이미지 2/3 HKC P774A Digitizer Replacement, Digitizer: 1 단계, 이미지 3/3
    • Insert the flat end of the spudger into the side of the device
    • This will create a gap between the device and screen housing.
    • Insert the plastic opening tool into this gap and move it along this gap.
    • Make sure not to bent the digitizer during this step.
    • The screen housing and device will now be separated.
  2. HKC P774A Digitizer Replacement: 2 단계, 이미지 1/3 HKC P774A Digitizer Replacement: 2 단계, 이미지 2/3 HKC P774A Digitizer Replacement: 2 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Once the digitizer has been been removed from the body, disconnect the digitizer band from the motherboard.
    • Two small black pins (circled in red) will need to be unlocked.
    • Unlock the pins by pulling them outward with the tweezers.
    • Make sure the pins are released entirely before attempting to remove the band.
    • Remove the band using the tweezers.
  3. HKC P774A Digitizer Replacement: 3 단계, 이미지 1/3 HKC P774A Digitizer Replacement: 3 단계, 이미지 2/3 HKC P774A Digitizer Replacement: 3 단계, 이미지 3/3
    • Once the digitizer has been disconnected from the motherboard, the LCD screen must be removed from the digitizer.
    • Push open the tabs (circled in red) using the flat end of the plastic spudger.
    • Be sure not to bend the digitizer while prying.
    • Continue to release all tabs while continuing to pry the LCD away from the digitizer.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Sean McCauley
회원 가입일: 10/26/15
512 평판
안내서 4개 작성하였습니다
Montana Tech, Team 10-1, Shirk Fall 2015 Montana Tech, Team 10-1, Shirk Fall 2015 회원
MTUM-SHIRK-F15S10G1
4 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 157
