주요 콘텐츠로 건너뛰기
HKC P776A Motherboard Replacement
필요한 것
  1. HKC P776A Motherboard Replacement, Separating Digitizer and Case: 1 단계, 이미지 1/1
    • Insert the plastic opening tool between the digitizer and the case.
    • Place the spudger in the gap created by the plastic opening tool to assist in separation.
  2. HKC P776A Motherboard Replacement: 2 단계, 이미지 1/2 HKC P776A Motherboard Replacement: 2 단계, 이미지 2/2
    • Slide the spudger along the perimeter of the device to fully separate the two pieces.
  3. HKC P776A Motherboard Replacement, Separating the Screen and Digitizer: 3 단계, 이미지 1/2 HKC P776A Motherboard Replacement, Separating the Screen and Digitizer: 3 단계, 이미지 2/2
    • Use your fingers to pop the screen out from the digitizer.
  4. HKC P776A Motherboard Replacement, Removing the Optical Cord from the Motherbaord: 4 단계, 이미지 1/1
    • With the plastic opening tool, lift the black latch up.
  5. HKC P776A Motherboard Replacement: 5 단계, 이미지 1/1
    • Pull the optical cord out from the motherboard.
  6. HKC P776A Motherboard Replacement, Separating the Screen and the Digitizer: 6 단계, 이미지 1/2 HKC P776A Motherboard Replacement, Separating the Screen and the Digitizer: 6 단계, 이미지 2/2
  7. HKC P776A Motherboard Replacement, Removing the Cable from the Motherboard: 7 단계, 이미지 1/2 HKC P776A Motherboard Replacement, Removing the Cable from the Motherboard: 7 단계, 이미지 2/2
    • Use the tip of the spudger to release the latches on the motherboard.
  8. HKC P776A Motherboard Replacement: 8 단계, 이미지 1/1
    • Remove the cable from the motherboard.
  9. HKC P776A Motherboard Replacement, Removing the Cable from the Moatherboard: 9 단계, 이미지 1/2 HKC P776A Motherboard Replacement, Removing the Cable from the Moatherboard: 9 단계, 이미지 2/2
  10. HKC P776A Motherboard Replacement: 10 단계, 이미지 1/2 HKC P776A Motherboard Replacement: 10 단계, 이미지 2/2
    • Remove the camera from the device.
  11. HKC P776A Motherboard Replacement, Wifi Antenna: 11 단계, 이미지 1/2 HKC P776A Motherboard Replacement, Wifi Antenna: 11 단계, 이미지 2/2
    • Peel off the tape that is attaching the wifi antenna to the case.
  12. HKC P776A Motherboard Replacement: 12 단계, 이미지 1/1
    • Using the soldering iron, heat up the solder that is attaching the antenna to the motheboard.
    • The heat from the soldering iron may cause personal injury or damage the internal components of the tablet.
  13. HKC P776A Motherboard Replacement: 13 단계, 이미지 1/1
    이 단계에 사용된 도구:
    Desoldering Pump
    $3.99
    구매
    • Suck up the leftover solder using the desoldering pump.
    • Remove the wifi antenna from the motherboard.
  14. HKC P776A Motherboard Replacement, Battery: 14 단계, 이미지 1/1
    • Insert the plastic opening tool between the battery and case.
    • Apply leverage to break the glue that is attaching the battery to the case.
  15. HKC P776A Motherboard Replacement: 15 단계, 이미지 1/1
    • Continue breaking the glue along the perimeter of the battery until the battery can be removed.
    • Breaking all the glue between the battery and case may take a long time.
  16. HKC P776A Motherboard Replacement: 16 단계, 이미지 1/2 HKC P776A Motherboard Replacement: 16 단계, 이미지 2/2
    • Using the soldering iron, heat up the solder that is attaching the battery to the motheboard.
  17. HKC P776A Motherboard Replacement: 17 단계, 이미지 1/1
    • Remove the battery from the motherboard.
  18. HKC P776A Motherboard Replacement, Motherboard: 18 단계, 이미지 1/3 HKC P776A Motherboard Replacement, Motherboard: 18 단계, 이미지 2/3 HKC P776A Motherboard Replacement, Motherboard: 18 단계, 이미지 3/3
    • Using the screwdriver, remove the four 4mm by 1.5mm screws that are attaching the motherboard to the case.
  19. HKC P776A Motherboard Replacement: 19 단계, 이미지 1/2 HKC P776A Motherboard Replacement: 19 단계, 이미지 2/2
    • Remove the black material that is covering the speaker.
  20. HKC P776A Motherboard Replacement: 20 단계, 이미지 1/1
    • Insert the spudger into the speaker slot on the back of the case.
  21. HKC P776A Motherboard Replacement: 21 단계, 이미지 1/1
    • Push the speaker out of the case with the spudger.
  22. HKC P776A Motherboard Replacement: 22 단계, 이미지 1/1
    • Remove the motherboard from the case.
결론
Ryan Gornati
회원 가입일: 01/22/15
409 평판
안내서 4개 작성하였습니다
USF Tampa, Team 7-6, Remmell Winter 2015 USF Tampa, Team 7-6, Remmell Winter 2015 회원
USFT-REMMELL-W15S7G6
3 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 6
전체 시간: 168
