주요 콘텐츠로 건너뛰기
HKC P776A Screen Replacement
필요한 것
  1. HKC P776A Screen Replacement, Separating Digitizer and Case: 1 단계, 이미지 1/1
    • Insert the plastic opening tool between the digitizer and the case.
    • Place the spudger in the gap created by the plastic opening tool to assist in separation.
  2. HKC P776A Screen Replacement: 2 단계, 이미지 1/2 HKC P776A Screen Replacement: 2 단계, 이미지 2/2
    • Slide the spudger along the perimeter of the device to fully separate the two pieces.
  3. HKC P776A Screen Replacement, Separating the Screen and Digitizer: 3 단계, 이미지 1/2 HKC P776A Screen Replacement, Separating the Screen and Digitizer: 3 단계, 이미지 2/2
    • Use your fingers to pop the screen out from the digitizer.
  4. HKC P776A Screen Replacement, Removing the Optical Cord from the Motherbaord: 4 단계, 이미지 1/1
    • With the plastic opening tool, lift the black latch up.
  5. HKC P776A Screen Replacement: 5 단계, 이미지 1/1
    • Pull the optical cord out from the motherboard.
결론
Spencer Pheasant
회원 가입일: 01/20/15
301 평판
안내서 3개 작성하였습니다
USF Tampa, Team 7-6, Remmell Winter 2015 USF Tampa, Team 7-6, Remmell Winter 2015 회원
USFT-REMMELL-W15S7G6
3 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 8
전체 시간: 223
