주요 콘텐츠로 건너뛰기
HKC P776A Wifi Antenna Replacement
필요한 것
  1. HKC P776A Wifi Antenna Replacement, Separating Digitizer and Case: 1 단계, 이미지 1/1
    • Insert the plastic opening tool between the digitizer and the case.
    • Place the spudger in the gap created by the plastic opening tool to assist in separation.
  2. HKC P776A Wifi Antenna Replacement: 2 단계, 이미지 1/2 HKC P776A Wifi Antenna Replacement: 2 단계, 이미지 2/2
    • Slide the spudger along the perimeter of the device to fully separate the two pieces.
  3. HKC P776A Wifi Antenna Replacement, Wifi Antenna: 3 단계, 이미지 1/2 HKC P776A Wifi Antenna Replacement, Wifi Antenna: 3 단계, 이미지 2/2
    • Peel off the tape that is attaching the wifi antenna to the case.
  4. HKC P776A Wifi Antenna Replacement: 4 단계, 이미지 1/1
    • Using the soldering iron, heat up the solder that is attaching the antenna to the motheboard.
    • The heat from the soldering iron may cause personal injury or damage the internal components of the tablet.
  5. HKC P776A Wifi Antenna Replacement: 5 단계, 이미지 1/1
    이 단계에 사용된 도구:
    Desoldering Pump
    $3.99
    구매
    • Suck up the leftover solder using the desoldering pump.
    • Remove the wifi antenna from the motherboard.
결론
Ryan Gornati
회원 가입일: 01/22/15
409 평판
안내서 4개 작성하였습니다
USF Tampa, Team 7-6, Remmell Winter 2015 USF Tampa, Team 7-6, Remmell Winter 2015 회원
USFT-REMMELL-W15S7G6
3 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 8
전체 시간: 127
