소개
This guide will walk the user through the basic steps necessary to replace the matrix on the HKC p886a 8" tablet.
필요한 것
Insert the flat tip of the metal spudger into the seam between the back panel and the screen.
Slide the spudger across the perimeter of the device and gently pry apart at each corner.
After the pressure clamps are released orient the device so that the speaker is to the right and the screen is tilted away from you.
Gently bend screen around LCD to disengage the pressure clamps.
Once all pressure clamps are disengaged, separate the LCD screen from the matrix with out touching the display portion of either component.
다른 한 분이 해당 안내서를 완성하였습니다.
