주요 콘텐츠로 건너뛰기
HMD Pulse+ Vibration Motor Replacement
필요한 것
  1. HMD Pulse+ Vibration Motor Replacement, Prepare your phone for disassembly: 1 단계, 이미지 1개 중 1개
    • Let your phone's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
    • Unplug all cables from your phone and completely power it down.
  2. HMD Pulse+ Vibration Motor Replacement, Remove the SIM card tray: 2 단계, 이미지 3개 중 1개 HMD Pulse+ Vibration Motor Replacement, Remove the SIM card tray: 2 단계, 이미지 3개 중 2개 HMD Pulse+ Vibration Motor Replacement, Remove the SIM card tray: 2 단계, 이미지 3개 중 3개
    • Firmly press a SIM eject tool, bit, or straightened paper clip into the SIM card tray hole on the left edge of your phone until the tray ejects.
    • Remove the SIM card tray.
    • During reassembly, use the tray's markings to orient and reinsert it properly.
  3. HMD Pulse+ Vibration Motor Replacement, Separate the back cover: 3 단계, 이미지 2개 중 1개 HMD Pulse+ Vibration Motor Replacement, Separate the back cover: 3 단계, 이미지 2개 중 2개
    • Insert the tip of an opening pick between the back cover and frame, at the SIM card tray cutout.
  4. HMD Pulse+ Vibration Motor Replacement: 4 단계, 이미지 3개 중 1개 HMD Pulse+ Vibration Motor Replacement: 4 단계, 이미지 3개 중 2개 HMD Pulse+ Vibration Motor Replacement: 4 단계, 이미지 3개 중 3개
    • Position the opening pick straight down and slide it along the left edge to begin unclipping the back cover.
  5. HMD Pulse+ Vibration Motor Replacement: 5 단계, 이미지 3개 중 1개 HMD Pulse+ Vibration Motor Replacement: 5 단계, 이미지 3개 중 2개 HMD Pulse+ Vibration Motor Replacement: 5 단계, 이미지 3개 중 3개
    • Continue sliding the pick around the perimeter of your phone until the back cover is fully unclipped.
    • The corners can be tricky to unclip and may take some force. If you're having trouble, try prying up with the pick.
    • Don't try to fully remove the cover yet, as a delicate cable still connects it to your phone.
  6. HMD Pulse+ Vibration Motor Replacement: 6 단계, 이미지 3개 중 1개 HMD Pulse+ Vibration Motor Replacement: 6 단계, 이미지 3개 중 2개 HMD Pulse+ Vibration Motor Replacement: 6 단계, 이미지 3개 중 3개
    • Carefully flip your phone over so the back cover is facing up.
    • Lift the back cover off the frame and flip it over the left edge of your phone, laying the cover flat on your work surface.
    • Be very careful not to strain the back cover's delicate cable.
    • During reassembly, place the back cover onto the frame and firmly squeeze around the perimeter to reengage all the clips.
  7. HMD Pulse+ Vibration Motor Replacement, Remove the motherboard cover: 7 단계, 이미지 2개 중 1개 HMD Pulse+ Vibration Motor Replacement, Remove the motherboard cover: 7 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Be very careful not to puncture the battery with your screwdriver.
    • Use a Phillips screwdriver to remove the nine 3.6 mm‑long screws securing the motherboard cover.
    • The screw near the center of the top edge is covered by a sticker. Pierce through it with your screwdriver, or use tweezers to remove it.
  8. HMD Pulse+ Vibration Motor Replacement: 8 단계, 이미지 3개 중 1개 HMD Pulse+ Vibration Motor Replacement: 8 단계, 이미지 3개 중 2개 HMD Pulse+ Vibration Motor Replacement: 8 단계, 이미지 3개 중 3개
    • Insert an opening pick between the right edge of the motherboard cover and frame.
    • Twist the pick to fully unclip the cover.
  9. HMD Pulse+ Vibration Motor Replacement: 9 단계, 이미지 2개 중 1개 HMD Pulse+ Vibration Motor Replacement: 9 단계, 이미지 2개 중 2개
    • Remove the motherboard shield and its connected graphite sheet.
    • During reassembly, set the motherboard shield into place and press down firmly around the perimeter to reengage the clips.
  10. HMD Pulse+ Vibration Motor Replacement, Disconnect the battery: 10 단계, 이미지 2개 중 1개 HMD Pulse+ Vibration Motor Replacement, Disconnect the battery: 10 단계, 이미지 2개 중 2개
    • Use the flat end of a spudger to pry up and disconnect the battery press connector from the bottom edge of the motherboard.
    • To reconnect these type of connectors, align the connector over its socket and press down with your fingertip—first at one side, then the other—until it clicks into place. Don't try to force the connector into place, or you may permanently damage it.
  11. HMD Pulse+ Vibration Motor Replacement, Remove the back cover: 11 단계, 이미지 2개 중 1개 HMD Pulse+ Vibration Motor Replacement, Remove the back cover: 11 단계, 이미지 2개 중 2개
    • Use the flat end of a spudger to pry up and disconnect the back cover press connector from the bottom edge of the motherboard.
  12. HMD Pulse+ Vibration Motor Replacement: 12 단계, 이미지 1개 중 1개
    • Remove the back cover.
  13. HMD Pulse+ Vibration Motor Replacement, Remove the charging board cover: 13 단계, 이미지 2개 중 1개 HMD Pulse+ Vibration Motor Replacement, Remove the charging board cover: 13 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use a Phillips screwdriver to remove the seven 3.6 mm‑long screws securing the charging board cover.
    • The screw near the center of the bottom edge is covered by a sticker. Pierce through it with your screwdriver, or use tweezers to remove it.
  14. HMD Pulse+ Vibration Motor Replacement: 14 단계, 이미지 3개 중 1개 HMD Pulse+ Vibration Motor Replacement: 14 단계, 이미지 3개 중 2개 HMD Pulse+ Vibration Motor Replacement: 14 단계, 이미지 3개 중 3개
    • Use your fingers to lift the bottom edge of the charging board cover until it unclips.
    • Remove the cover.
  15. HMD Pulse+ Vibration Motor Replacement, Disconnect the charging board: 15 단계, 이미지 2개 중 1개 HMD Pulse+ Vibration Motor Replacement, Disconnect the charging board: 15 단계, 이미지 2개 중 2개
    • Use the point of a spudger to pry up and disconnect the charging board cable press connector on the top edge of the board.
  16. HMD Pulse+ Vibration Motor Replacement: 16 단계, 이미지 2개 중 1개 HMD Pulse+ Vibration Motor Replacement: 16 단계, 이미지 2개 중 2개
    • Slide one arm of a pair of tweezers under the metal neck of the black antenna cable's connector head, near the center of the board.
    • Lift straight up to disconnect the cable.
    • To reconnect the cable, hold the metal head over its socket and press down with the flat end of a spudger—it should snap into place. If it's not connecting, reposition the head and try again.
  17. HMD Pulse+ Vibration Motor Replacement: 17 단계, 이미지 3개 중 1개 HMD Pulse+ Vibration Motor Replacement: 17 단계, 이미지 3개 중 2개 HMD Pulse+ Vibration Motor Replacement: 17 단계, 이미지 3개 중 3개
    • Use the point of a spudger to pry up and unclip the left and right edges of the charging board.
  18. HMD Pulse+ Vibration Motor Replacement, Remove the charging board: 18 단계, 이미지 2개 중 1개 HMD Pulse+ Vibration Motor Replacement, Remove the charging board: 18 단계, 이미지 2개 중 2개
    • Remove the charging board.
    • During reassembly:
    • Make sure the interconnect cable is flipped up and the black antenna cable is routed through its groove on the right edge.
    • Set the charging board into its recess and press down on the edges to clip it into place.
  19. HMD Pulse+ Vibration Motor Replacement, Remove the vibration motor: 19 단계, 이미지 3개 중 1개 HMD Pulse+ Vibration Motor Replacement, Remove the vibration motor: 19 단계, 이미지 3개 중 2개 HMD Pulse+ Vibration Motor Replacement, Remove the vibration motor: 19 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    Tesa 61395 Tape
    $2.99
    • Insert the point of a spudger under the left side of the vibration motor (near the small notch) and pry it up.
    • If the motor isn't budging, use a pipette or syringe to apply a drop of isopropyl alcohol (>90%) under the motor to soften the adhesive.
    • Remove the vibration motor.
    • During reassembly, use a small piece of double-sided tape to secure the vibration motor to the frame.
결론
작성자
2다른 기여자 명과 함께
Spencer Day
회원 가입일: 09/14/22
150,212 평판
안내서 995개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,648개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 7
전체 시간: 167
