주요 콘텐츠로 건너뛰기
HMD Skyline Business Back Cover Replacement
필요한 것
  1. HMD Skyline Business Back Cover Replacement, Prepare your phone for disassembly: 1 단계, 이미지 1개 중 1개
    • Let your phone's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
    • Unplug all cables and completely power off your phone.
  2. HMD Skyline Business Back Cover Replacement, Separate the back cover: 2 단계, 이미지 3개 중 1개 HMD Skyline Business Back Cover Replacement, Separate the back cover: 2 단계, 이미지 3개 중 2개 HMD Skyline Business Back Cover Replacement, Separate the back cover: 2 단계, 이미지 3개 중 3개
    • A screw‑driven camshaft in the bottom left corner pushes the back cover away from the phone, creating a gap to begin separating the cover.
    • With the back cover facing up, use a T3 Torx screwdriver to turn the screw in the bottom edge counterclockwise until the back cover pops up.
  3. HMD Skyline Business Back Cover Replacement: 3 단계, 이미지 3개 중 1개 HMD Skyline Business Back Cover Replacement: 3 단계, 이미지 3개 중 2개 HMD Skyline Business Back Cover Replacement: 3 단계, 이미지 3개 중 3개
    • Before separating the back cover, note the following:
    • There's a seam just under the back cover panel. Don't insert your tool here.
    • Insert your tool completely under the back cover, so it's between the frame and the underside of the back cover.
    • Insert an opening pick under the bottom left corner of the back cover and slide it along the bottom edge to release the clips and separate the adhesive.
    • You should feel and hear the back cover clips release. If you don't, insert the pick deeper and try again.
  4. HMD Skyline Business Back Cover Replacement: 4 단계, 이미지 3개 중 1개 HMD Skyline Business Back Cover Replacement: 4 단계, 이미지 3개 중 2개 HMD Skyline Business Back Cover Replacement: 4 단계, 이미지 3개 중 3개
    • Continue sliding the pick under the perimeter of the back cover to fully separate the clips and adhesive.
  5. HMD Skyline Business Back Cover Replacement, Remove the back cover: 5 단계, 이미지 3개 중 1개 HMD Skyline Business Back Cover Replacement, Remove the back cover: 5 단계, 이미지 3개 중 2개 HMD Skyline Business Back Cover Replacement, Remove the back cover: 5 단계, 이미지 3개 중 3개
    • Lift and remove the back cover.
    • During reassembly:
    • Now is a good time to test your phone before sealing it up. Power it on and check that it works. Power it back down before you continue reassembly.
    • If you're installing a new back cover:
    • Make sure you remove all liners from the underside.
    • Use the flat end of a spudger to press the small cable above the wireless charging coil into place over its alignment posts.
    • Place the back cover onto the frame and firmly squeeze around the perimeter to reengage all the clips.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Spencer Day
회원 가입일: 09/14/22
94,629 평판
안내서 662개를 작성함
iFixit iFixit 회원
Staff
118 회원들
안내서 19,418개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 17
전체 시간: 366
