소개
Outline what you are going to teach someone how to do.
필요한 것
Use the plastic opening tool to pry off the rubber cover at the bottom of the speaker.
Gently remove the rubber cover to expose the screws. If necessary, poke holes through the glue residue to expose the screw heads.
Once you have exposed the screws, use a #1 Phillips screwdriver to remove the four 9 mm screws.
Once you've removed the screws, open the case slowly. The battery is covered in blue packaging.
Use a solder gun to remove the battery attachments from the motherboard.
다른 41명이 해당 안내서를 완성하였습니다.
댓글 18개
Looks like a great solution to fixing the speaker with a battery with a short life span. But what's the amperage of the lithium barberry and where can I purchase one ?
Did you ever find out where to purchase a new battery for it?
Hey Stephen. Can you tell me where i can buy a replacement battery for my P120
On my Model: HX-P240A
KANYO 383541P 3.7V
520mAh 1.924Wh
534114364A17142
