주요 콘텐츠로 건너뛰기
HMDX Jam Plus Micro USB Jack Replacement
필요한 것
  1. HMDX Jam Plus  Micro USB Jack Replacement, Battery: 1 단계, 이미지 1/3 HMDX Jam Plus  Micro USB Jack Replacement, Battery: 1 단계, 이미지 2/3 HMDX Jam Plus  Micro USB Jack Replacement, Battery: 1 단계, 이미지 3/3
    • Flip the device over so the bottom is facing up.
    • Use the large plastic opening tool to gently pry the rubber base from the device.
    • Slowly move the plastic opening tool around the edge of the rubber base to separate it from the plastic.
  2. HMDX Jam Plus  Micro USB Jack Replacement: 2 단계, 이미지 1/2 HMDX Jam Plus  Micro USB Jack Replacement: 2 단계, 이미지 2/2
    • Use a Phillips #1 screwdriver to remove the four black 9mm screws from the device.
  3. HMDX Jam Plus  Micro USB Jack Replacement: 3 단계, 이미지 1/2 HMDX Jam Plus  Micro USB Jack Replacement: 3 단계, 이미지 2/2
    • Gently separate the base from the rest of the device to reveal the battery and the main board.
  4. HMDX Jam Plus  Micro USB Jack Replacement: 4 단계, 이미지 1/3 HMDX Jam Plus  Micro USB Jack Replacement: 4 단계, 이미지 2/3 HMDX Jam Plus  Micro USB Jack Replacement: 4 단계, 이미지 3/3
    • Carefully use the plastic opening tool to remove the glue around the battery and speaker connectors.
    • Pull gently on the connectors to separate each one from the main board.
    • The battery is connected to board in the red socket and the speaker is connected in the white socket.
  5. HMDX Jam Plus  Micro USB Jack Replacement: 5 단계, 이미지 1/3 HMDX Jam Plus  Micro USB Jack Replacement: 5 단계, 이미지 2/3 HMDX Jam Plus  Micro USB Jack Replacement: 5 단계, 이미지 3/3
    • Batteries can be very dangerous if punctured. Use extra caution when using tools around the battery.
    • Use the plastic opening tool to gently pry the battery free from the rest of the device.
  6. HMDX Jam Plus  Micro USB Jack Replacement: 6 단계, 이미지 1/2 HMDX Jam Plus  Micro USB Jack Replacement: 6 단계, 이미지 2/2
    • Use new adhesive to secure battery back to the rest of the device.
  7. HMDX Jam Plus  Micro USB Jack Replacement, Micro USB Jack: 7 단계, 이미지 1/2 HMDX Jam Plus  Micro USB Jack Replacement, Micro USB Jack: 7 단계, 이미지 2/2
    • Remove the three black 6mm screws from the main board using a Philips #00 screwdriver.
  8. HMDX Jam Plus  Micro USB Jack Replacement: 8 단계, 이미지 1/2 HMDX Jam Plus  Micro USB Jack Replacement: 8 단계, 이미지 2/2
    • Carefully lift the main board away from the plastic.
    • Lift the side with the buttons first and be careful not to damage the Line In Jack or the Micro USB Jack.
  9. HMDX Jam Plus  Micro USB Jack Replacement: 9 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Use the Micro soldering iron to heat up each pad and use the desoldering wick to wick up the melted solder.
    • The surface mount jack should pull from the surface without much force. Use tweezers to apply upward pressure on on the jack.
    • Do not apply too much heat to the board as it may damage other portions of the board.
결론
Maxwell Erickson
회원 가입일: 10/22/15
587 평판
안내서 4개 작성하였습니다
Montana Tech, Team 10-3, Shirk Fall 2015 Montana Tech, Team 10-3, Shirk Fall 2015 회원
MTUM-SHIRK-F15S10G3
4 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 13
전체 시간: 744
