소개
Sometimes a devices battery has been recharged too many times. This recharging causes the battery to diminish over time and hold less of a charge. The purpose of this guide is to demonstrate how to replace a bad or warn battery on the HMDX Jam Plus.
필요한 것
Flip the device over so the bottom is facing up.
Use the large plastic opening tool to gently pry the rubber base from the device.
Slowly move the plastic opening tool around the edge of the rubber base to separate it from the plastic.
다른 4명이 해당 안내서를 완성하였습니다.
댓글 5개
Where may battery be purchased?
Thanks,
zappenfusen
warnsdorff - 답글
Where to purchase battery for hmdx jam speaker
Where can a battery be purchased?
What kind (especifications) that battery?
Where to buy battery for HMDX JAM.Bluetooth speaker
