주요 콘텐츠로 건너뛰기
HP 10 2101 Microphone Replacement
필요한 것
  1. HP 10 2101 Microphone Replacement, Back Panel: 1 단계, 이미지 1/1
    • Identify the SD card port.
  2. HP 10 2101 Microphone Replacement: 2 단계, 이미지 1/1
    • Insert the smallest plastic opening tool into the SD card port. Gently pry until the back panel separates from the screen panel.
    • Do not insert opening tool too far. Avoid making contact with the metal inside the port.
  3. HP 10 2101 Microphone Replacement: 3 단계, 이미지 1/1
    • Slide the opening tool along the seam between the back panel and the screen panel, prying the panels apart as you move around the edges.
  4. HP 10 2101 Microphone Replacement: 4 단계, 이미지 1/1
    • Separate the back panel from the rest of the device.
  5. HP 10 2101 Microphone Replacement, Microphone: 5 단계, 이미지 1/1
    • Desolder the microphone wires from the motherboard.
  6. HP 10 2101 Microphone Replacement: 6 단계, 이미지 1/1
    • Separate the microphone from the rest of the device.
결론
Bryce Harmsen
회원 가입일: 09/25/18
668 평판
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 137
