이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Insert the smallest plastic opening tool into the SD card port. Gently pry until the back panel separates from the screen panel.
Slide the opening tool along the seam between the back panel and the screen panel, prying the panels apart as you move around the edges.
Remove the pieces of black tape that hold the speaker wires to the battery.
Use the Phillips #00 screwdriver to remove the 4mm screws from the speaker.
There are two screws holding both speakers to the plastic device frame.
