소개
If your computer won't charge and you have already ruled out a defunct charger, you can try replacing the power jack using these steps.
부품
지정된 부품이 없습니다.
  1. Remove battery by pushing the two buttons inward.
    • Remove battery by pushing the two buttons inward.
  2. Remove the two rubber feet next to the battery.
    • Remove the two rubber feet next to the battery.
  3. Remove all 14 Phillips head #0  screws.
    • Remove all 14 Phillips head #0 screws.
  4. 안드로이드 수리 키트
    새 스크린 혹은 배터리는 단 하나의 키트로 충분합니다.
    지금 장보기
    안드로이드 수리 키트
    지금 장보기
  5. Use a plastic opener tool to pry off the black backplate.
    • Use a plastic opener tool to pry off the black backplate.
  6. Remove the black tape near the power jack. Remove the screws connecting monitor to the bottom of the computer.
    • Remove the black tape near the power jack.
    • Remove the screws connecting monitor to the bottom of the computer.
  7. Position the metal fittings attached to the monitor out of the way.
    • Position the metal fittings attached to the monitor out of the way.
    • The monitor is still attached by wires — be careful not to pull on it too hard.
  8. Disconnect the power jack from the motherboard. Remove the power jack by lifting it up. An opener tool may make this easier.
    • Disconnect the power jack from the motherboard.
    • Remove the power jack by lifting it up.
    • An opener tool may make this easier.
결론
Antonio Leonti
회원 가입일: 2018년 10월 26일
383 Reputation
안내서 3개 작성하였습니다
UMass Dartmouth, Team S1-G7, Simcock Fall 2018 UMass Dartmouth, Team S1-G7, Simcock Fall 2018 회원
UMASSD-SIMCOCK-F18S1G7
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 97
