주요 콘텐츠로 건너뛰기
HP 14-am052nr Daughterboard Replacement
필요한 것
  1. HP 14-am052nr Daughterboard Replacement, Battery: 1 단계, 이미지 1/3 HP 14-am052nr Daughterboard Replacement, Battery: 1 단계, 이미지 2/3 HP 14-am052nr Daughterboard Replacement, Battery: 1 단계, 이미지 3/3
    • Turn the laptop over to its bottom so that the backside is facing you.
    • Using your fingers, push the two locking tabs inwards to release the battery.
    • Remove the battery from the device.
  2. HP 14-am052nr Daughterboard Replacement, Back Panel: 2 단계, 이미지 1/2 HP 14-am052nr Daughterboard Replacement, Back Panel: 2 단계, 이미지 2/2
    • After removing the battery with the laptop on its back, expose screws that are hidden under the rubber feet and the center label.
    • Using the Phillips #0 screwdriver, remove fourteen (14) 6 mm screws from the back panel.
  3. HP 14-am052nr Daughterboard Replacement: 3 단계, 이미지 1/2 HP 14-am052nr Daughterboard Replacement: 3 단계, 이미지 2/2
    • Use a prying tool to remove the back panel from the base of the computer.
  4. HP 14-am052nr Daughterboard Replacement, Daughterboard: 4 단계, 이미지 1/2 HP 14-am052nr Daughterboard Replacement, Daughterboard: 4 단계, 이미지 2/2
    • Disconnect the daughterboard from the connector with your thumb and pointer finger.
  5. HP 14-am052nr Daughterboard Replacement: 5 단계, 이미지 1/1
    • Use the Phillips #0 screwdriver to remove three 3 mm screws.
  6. HP 14-am052nr Daughterboard Replacement: 6 단계, 이미지 1/1
    • Remove the daughterboard from the device.
결론
Paige Fonseca
회원 가입일: 10/25/21
217 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team 3-3, Sinclaire Fall 2021 UMass Dartmouth, Team 3-3, Sinclaire Fall 2021 회원
UMASSD-SINCLAIRE-F21S3G3
3 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 12
전체 시간: 330
