주요 콘텐츠로 건너뛰기
HP 14-an012nr Fan Replacement
필요한 것
  1. HP 14-an012nr Fan Replacement, Battery: 1 단계, 이미지 1/3 HP 14-an012nr Fan Replacement, Battery: 1 단계, 이미지 2/3 HP 14-an012nr Fan Replacement, Battery: 1 단계, 이미지 3/3
    • Remove the battery by sliding both sliders inward.
  2. HP 14-an012nr Fan Replacement, Back Panel: 2 단계, 이미지 1/3 HP 14-an012nr Fan Replacement, Back Panel: 2 단계, 이미지 2/3 HP 14-an012nr Fan Replacement, Back Panel: 2 단계, 이미지 3/3
    • Remove the eight 6 mm screws from the back panel using a Phillips #1 screwdriver.
    • Remove the rubber pads from the upper corners of the laptop to reveal two screws on each side.
    • Remove six 4 mm screws using a Phillips #1 screwdriver.
    • Pry the back panel off using an opening tool, working your way around the edges.
  3. HP 14-an012nr Fan Replacement, Fan: 3 단계, 이미지 1/3 HP 14-an012nr Fan Replacement, Fan: 3 단계, 이미지 2/3 HP 14-an012nr Fan Replacement, Fan: 3 단계, 이미지 3/3
    • Remove the two 3 mm screws that secure the fan.
    • Gently disconnect the power cable; it can tear easily.
    • Remove the fan.
  4. HP 14-an012nr Fan Replacement: 4 단계, 이미지 1/2 HP 14-an012nr Fan Replacement: 4 단계, 이미지 2/2
    • Clean the area where the fan was located with a clean soft cloth or cotton swab.
    • Once cleaned and free of dust place the new fan and follow the steps in reverse to rebuild the laptop.
결론
Christopher Brackeen
회원 가입일: 09/07/23
85 평판
안내서 1개 작성함
Gateway, Team 2-2, Gonzalez Fall 2023 Gateway, Team 2-2, Gonzalez Fall 2023 회원
GCC-GONZALEZ-F23S2G2
5 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 12
전체 시간: 109
