주요 콘텐츠로 건너뛰기
HP 14-fq1025nr Keyboard Replacement
필요한 것
  1. HP 14-fq1025nr Keyboard Replacement, Back Cover: 1 단계, 이미지 1/1
    • Flip the laptop upside down so the bottom cover is facing up.
  2. HP 14-fq1025nr Keyboard Replacement: 2 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Use a pair of tweezers to grab and pull the feet off of the cover.
  3. HP 14-fq1025nr Keyboard Replacement: 3 단계, 이미지 1/1
    • Remove the two 4 mm screws using a Phillips #0 screwdriver.
    • Remove the six remaining 6 mm screws located around the edges and underneath the feet using a Phillips #0 screwdriver.
  4. HP 14-fq1025nr Keyboard Replacement: 4 단계, 이미지 1/1
    • Flip the laptop right-side up and slide an iFixit opening tool and/or Jimmy inside of the bottom cover seam to pry it open.
  5. HP 14-fq1025nr Keyboard Replacement: 5 단계, 이미지 1/1
    • Remove the bottom cover.
  6. HP 14-fq1025nr Keyboard Replacement, Battery: 6 단계, 이미지 1/2 HP 14-fq1025nr Keyboard Replacement, Battery: 6 단계, 이미지 2/2
    • Remove the four gray 3 mm screws holding down the battery using a Phillips #0 screwdriver.
  7. HP 14-fq1025nr Keyboard Replacement: 7 단계, 이미지 1/1
    • Remove the battery.
  8. HP 14-fq1025nr Keyboard Replacement, Fan: 8 단계, 이미지 1/1
    • Remove the three silver screws (one 2 mm screw and two 4 mm screws) holding down the fan using a Phillips #0 screwdriver.
  9. HP 14-fq1025nr Keyboard Replacement: 9 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Unplug the fan’s power cord from the motherboard.
    • Use tweezers to pull the plug out, if needed.
  10. HP 14-fq1025nr Keyboard Replacement: 10 단계, 이미지 1/1
    • Remove the fan.
  11. HP 14-fq1025nr Keyboard Replacement, Heat Sink: 11 단계, 이미지 1/1
    • Remove the four gray 3 mm screws around the heat sink using a Phillips #0 screwdriver.
    • Remove the heat sink.
  12. HP 14-fq1025nr Keyboard Replacement, Speakers: 12 단계, 이미지 1/2 HP 14-fq1025nr Keyboard Replacement, Speakers: 12 단계, 이미지 2/2
    • Using a Phillips #0 screwdriver, remove the three black 5 mm screws holding down the speaker:
    • Two screws on the left side
    • One screw on the right side
  13. HP 14-fq1025nr Keyboard Replacement: 13 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Unplug the speaker wire.
    • Use tweezers if needed.
  14. HP 14-fq1025nr Keyboard Replacement: 14 단계, 이미지 1/1
    • Remove the speaker.
  15. HP 14-fq1025nr Keyboard Replacement, SSD: 15 단계, 이미지 1/1
    • Remove the single 6 mm screw holding down the SSD using a Phillips #0 screwdriver.
  16. HP 14-fq1025nr Keyboard Replacement: 16 단계, 이미지 1/1
    • Slide the SSD out of the slot.
  17. HP 14-fq1025nr Keyboard Replacement, Motherboard: 17 단계, 이미지 1/3 HP 14-fq1025nr Keyboard Replacement, Motherboard: 17 단계, 이미지 2/3 HP 14-fq1025nr Keyboard Replacement, Motherboard: 17 단계, 이미지 3/3
    • Remove the five 3 mm gray screws from around the motherboard using a Phillips #00 screwdriver.
  18. HP 14-fq1025nr Keyboard Replacement: 18 단계, 이미지 1/2 HP 14-fq1025nr Keyboard Replacement: 18 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Unplug the wire connections.
  19. HP 14-fq1025nr Keyboard Replacement: 19 단계, 이미지 1/1
    • Remove the motherboard.
    • Use the iFixit opening tool to pry it out if needed.
  20. HP 14-fq1025nr Keyboard Replacement, Screen: 20 단계, 이미지 1/3 HP 14-fq1025nr Keyboard Replacement, Screen: 20 단계, 이미지 2/3 HP 14-fq1025nr Keyboard Replacement, Screen: 20 단계, 이미지 3/3
    • Remove the four black 5 mm screws holding down the two silver screen hinges using a Phillips #00 screwdriver.
  21. HP 14-fq1025nr Keyboard Replacement: 21 단계, 이미지 1/2 HP 14-fq1025nr Keyboard Replacement: 21 단계, 이미지 2/2
    • Unplug the screen from the motherboard by lifting the wire cover and removing the screen cord.
    • Separate the hinges from the computer.
  22. HP 14-fq1025nr Keyboard Replacement: 22 단계, 이미지 1/1
    • Remove the screen.
  23. HP 14-fq1025nr Keyboard Replacement, Keyboard: 23 단계, 이미지 1/1
    • Use an iFixit opening tool to remove all the plastic hold downs from the keyboard cover.
  24. HP 14-fq1025nr Keyboard Replacement: 24 단계, 이미지 1/1
    • Remove all remaining plastic hold downs on the main keyboard with an iFixit opening tool.
  25. HP 14-fq1025nr Keyboard Replacement: 25 단계, 이미지 1/1
    • Push the keyboard out of the computer.
    • During reassembly, make sure that the keyboard is tightened properly.
결론
Yasli Kanimba Murenzi
회원 가입일: 09/27/22
193 평판
안내서 2개 작성하였습니다
Utah Tech University, Team 1-6, McMurrin Fall 2022 Utah Tech University, Team 1-6, McMurrin Fall 2022 회원
UTAHTECH-MCMURRIN-F22S1G6
3 회원들
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 17
전체 시간: 227
