주요 콘텐츠로 건너뛰기
HP 15-AF131DX Hard Drive Replacement
필요한 것
  1. HP 15-AF131DX Hard Drive Replacement, Hard Drive: 1 단계, 이미지 1/2 HP 15-AF131DX Hard Drive Replacement, Hard Drive: 1 단계, 이미지 2/2
    • Use a Phillips screwdriver to remove the 10 visible screws on the bottom.
    • Peel up the rubber feet near the hinges.
    • Remove the screw under each.
  2. HP 15-AF131DX Hard Drive Replacement: 2 단계, 이미지 1/2 HP 15-AF131DX Hard Drive Replacement: 2 단계, 이미지 2/2
    이 단계에 사용된 도구:
    Plastic Cards
    $2.99
    구매
    • Turn the computer over and use a plastic card, opening pick, or opening tool to pry the space between the keyboard and bottom surface of the computer.
    • Work plastic card, opening pick, or opening tool carefully around the three edges (excluding the side with the screen, which should be positioned at 90 degrees.
    • Gently lift the top surface of the bottom half of the laptop, revealing the hard drive.
  3. HP 15-AF131DX Hard Drive Replacement: 3 단계, 이미지 1/3 HP 15-AF131DX Hard Drive Replacement: 3 단계, 이미지 2/3 HP 15-AF131DX Hard Drive Replacement: 3 단계, 이미지 3/3
    • Remove the three screws that hold the hard drive in place.
    • Lift the hard drive slightly and disconnect the SATA hard drive connector to free the hard drive.
    • Remove the hard drive.
결론
다른 8명이 해당 안내서를 완성하였습니다.
Anthony Martinez
회원 가입일: 10/05/17
526 평판
안내서 3개 작성하였습니다
Cal Poly, Team S6-G2, Banghart Fall 2017 Cal Poly, Team S6-G2, Banghart Fall 2017 회원
CPSU-BANGHART-F17S6G2
5 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 9
전체 시간: 5,446
