주요 콘텐츠로 건너뛰기
HP 15-AF131DX Optical Drive Replacement
필요한 것
  1. HP 15-AF131DX Optical Drive Replacement, Optical Drive: 1 단계, 이미지 1/2 HP 15-AF131DX Optical Drive Replacement, Optical Drive: 1 단계, 이미지 2/2
    • Using a small Phillips screwdriver, remove the Phillips screw in the middle of the bottom of the computer.
    • Pull the CD/DVD drive outward to slide it away from the computer.
  2. HP 15-AF131DX Optical Drive Replacement: 2 단계, 이미지 1/1
    • To open the drive use an unbent paperclip and press it into the small hole until the disc tray releases.
    • Pull the disc tray out from the front until it is as far as it will go out of the optical drive.
  3. HP 15-AF131DX Optical Drive Replacement: 3 단계, 이미지 1/3 HP 15-AF131DX Optical Drive Replacement: 3 단계, 이미지 2/3 HP 15-AF131DX Optical Drive Replacement: 3 단계, 이미지 3/3
    • To remove excess parts from the optical drive press down on the plastic tab behind the tray's bezel.
    • Gently pry the bezel from the face of the optical drive.
    • With a smaller phillips head screwdriver, remove the screws on the back of the drive, then remove the small metal bracket.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Aaron McCallister
회원 가입일: 09/26/17
128 평판
안내서 1개 작성함
Cal Poly, Team S6-G2, Banghart Fall 2017 Cal Poly, Team S6-G2, Banghart Fall 2017 회원
CPSU-BANGHART-F17S6G2
5 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 13
전체 시간: 453
