주요 콘텐츠로 건너뛰기
HP 15-AF131DX Trackpad Button Circuit Board Replacement
필요한 것
  1. HP 15-AF131DX Trackpad Button Circuit Board Replacement, Battery: 1 단계, 이미지 1/2 HP 15-AF131DX Trackpad Button Circuit Board Replacement, Battery: 1 단계, 이미지 2/2
    • Turn the computer upside down on a level surface.
    • Slide the battery lock to unlock the battery.
    • Slide the battery release latch. The latch will click when the battery is released.
    • Lift the battery from the middle to remove it from the computer.
    • The latch will click again when a battery is reinstalled. Switch the battery lock back to locked after reinstalling a battery to keep it secure.
  2. HP 15-AF131DX Trackpad Button Circuit Board Replacement, Optical Drive: 2 단계, 이미지 1/2 HP 15-AF131DX Trackpad Button Circuit Board Replacement, Optical Drive: 2 단계, 이미지 2/2
    • Using a small Phillips screwdriver, remove the Phillips screw in the middle of the bottom of the computer.
    • Pull the CD/DVD drive outward to slide it away from the computer.
  3. HP 15-AF131DX Trackpad Button Circuit Board Replacement: 3 단계, 이미지 1/1
    • To open the drive use an unbent paperclip and press it into the small hole until the disc tray releases.
    • Pull the disc tray out from the front until it is as far as it will go out of the optical drive.
  4. HP 15-AF131DX Trackpad Button Circuit Board Replacement: 4 단계, 이미지 1/3 HP 15-AF131DX Trackpad Button Circuit Board Replacement: 4 단계, 이미지 2/3 HP 15-AF131DX Trackpad Button Circuit Board Replacement: 4 단계, 이미지 3/3
    • To remove excess parts from the optical drive press down on the plastic tab behind the tray's bezel.
    • Gently pry the bezel from the face of the optical drive.
    • With a smaller phillips head screwdriver, remove the screws on the back of the drive, then remove the small metal bracket.
  5. HP 15-AF131DX Trackpad Button Circuit Board Replacement, Trackpad Button Circuit Board: 5 단계, 이미지 1/2 HP 15-AF131DX Trackpad Button Circuit Board Replacement, Trackpad Button Circuit Board: 5 단계, 이미지 2/2
    • Remove two rubber feet by peeling them off.
    • Remove twelve Phillips head 8.8mm screws using the Phillips #0 Screwdriver.
  6. HP 15-AF131DX Trackpad Button Circuit Board Replacement: 6 단계, 이미지 1/3 HP 15-AF131DX Trackpad Button Circuit Board Replacement: 6 단계, 이미지 2/3 HP 15-AF131DX Trackpad Button Circuit Board Replacement: 6 단계, 이미지 3/3
    • Remove the bottom of the plastic case using a blue plastic opening tool.
    • The Trackpad Button Circuit Board is found in the red box.
  7. HP 15-AF131DX Trackpad Button Circuit Board Replacement: 7 단계, 이미지 1/2 HP 15-AF131DX Trackpad Button Circuit Board Replacement: 7 단계, 이미지 2/2
    • Remove the two 3.3mm Phillips-head screws that secure the trackpad circuit board to the top cover.
  8. HP 15-AF131DX Trackpad Button Circuit Board Replacement: 8 단계, 이미지 1/2 HP 15-AF131DX Trackpad Button Circuit Board Replacement: 8 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Lift the plastic wire lock bracket.
    • Pull on the blue tab to remove the wire using the tweezers tool to make sure there is no damage as you pull.
  9. HP 15-AF131DX Trackpad Button Circuit Board Replacement: 9 단계, 이미지 1/2 HP 15-AF131DX Trackpad Button Circuit Board Replacement: 9 단계, 이미지 2/2
    • Lift the second plastic wire lock bracket.
    • Pull on the purple tab using tweezers to remove the wire.
  10. HP 15-AF131DX Trackpad Button Circuit Board Replacement: 10 단계, 이미지 1/1
    • Lift and remove the trackpad button circuit board.
결론
Adrianna
회원 가입일: 11/01/18
133 평판
안내서 1개 작성함
IUPUI, Team S2-G2, Harley Fall 2018 IUPUI, Team S2-G2, Harley Fall 2018 회원
IUPUI-HARLEY-F18S2G2
3 회원들
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 3
전체 시간: 358
