주요 콘텐츠로 건너뛰기
HP 15-AF131DX Wireless Network Card Replacement
필요한 것
  1. HP 15-AF131DX Wireless Network Card Replacement, Battery: 1 단계, 이미지 1/2 HP 15-AF131DX Wireless Network Card Replacement, Battery: 1 단계, 이미지 2/2
    • Turn the computer upside down on a level surface.
    • Slide the battery lock to unlock the battery.
    • Slide the battery release latch. The latch will click when the battery is released.
    • Lift the battery from the middle to remove it from the computer.
    • The latch will click again when a battery is reinstalled. Switch the battery lock back to locked after reinstalling a battery to keep it secure.
  2. HP 15-AF131DX Wireless Network Card Replacement, Optical Drive: 2 단계, 이미지 1/2 HP 15-AF131DX Wireless Network Card Replacement, Optical Drive: 2 단계, 이미지 2/2
    • Using a small Phillips screwdriver, remove the Phillips screw in the middle of the bottom of the computer.
    • Pull the CD/DVD drive outward to slide it away from the computer.
  3. HP 15-AF131DX Wireless Network Card Replacement: 3 단계, 이미지 1/1
    • To open the drive use an unbent paperclip and press it into the small hole until the disc tray releases.
    • Pull the disc tray out from the front until it is as far as it will go out of the optical drive.
  4. HP 15-AF131DX Wireless Network Card Replacement: 4 단계, 이미지 1/3 HP 15-AF131DX Wireless Network Card Replacement: 4 단계, 이미지 2/3 HP 15-AF131DX Wireless Network Card Replacement: 4 단계, 이미지 3/3
    • To remove excess parts from the optical drive press down on the plastic tab behind the tray's bezel.
    • Gently pry the bezel from the face of the optical drive.
    • With a smaller phillips head screwdriver, remove the screws on the back of the drive, then remove the small metal bracket.
  5. HP 15-AF131DX Wireless Network Card Replacement, Wireless Network Card: 5 단계, 이미지 1/2 HP 15-AF131DX Wireless Network Card Replacement, Wireless Network Card: 5 단계, 이미지 2/2
    • The first step of this process is to peel off two rubber feet from the bottom of the laptop.
    • Then remove twelve 8.8 mm screws using the Phillips #0 Screwdriver.
  6. HP 15-AF131DX Wireless Network Card Replacement: 6 단계, 이미지 1/3 HP 15-AF131DX Wireless Network Card Replacement: 6 단계, 이미지 2/3 HP 15-AF131DX Wireless Network Card Replacement: 6 단계, 이미지 3/3
    • Remove the bottom of the plastic case using a blue plastic opening tool.
    • The HP Wireless Network Card is found in Picture 3, circled in red.
  7. HP 15-AF131DX Wireless Network Card Replacement: 7 단계, 이미지 1/3 HP 15-AF131DX Wireless Network Card Replacement: 7 단계, 이미지 2/3 HP 15-AF131DX Wireless Network Card Replacement: 7 단계, 이미지 3/3
    • Remove one 3.3 mm screw using Phillips #0 screwdriver.
    • Pop off the connection wire by pulling the wire upwards off the stud on the HP Wireless Network Card.
    • Pull out the HP Wireless Network Card.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Clayton Mettert
회원 가입일: 11/01/18
121 평판
안내서 1개 작성함
IUPUI, Team S2-G2, Harley Fall 2018 IUPUI, Team S2-G2, Harley Fall 2018 회원
IUPUI-HARLEY-F18S2G2
3 회원들
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 620
