주요 콘텐츠로 건너뛰기
HP 15-BA078DX Back Panel Replacement
필요한 것
  1. HP 15-BA078DX Back Panel Replacement, Battery: 1 단계, 이미지 1/3 HP 15-BA078DX Back Panel Replacement, Battery: 1 단계, 이미지 2/3 HP 15-BA078DX Back Panel Replacement, Battery: 1 단계, 이미지 3/3
    • Unclip the two latches on the bottom of the laptop.
    • Slide the battery straight out while holding the clip open.
  2. HP 15-BA078DX Back Panel Replacement, Disc Drive: 2 단계, 이미지 1/1
    • Using the Phillips #0 screwdriver, remove the 7.5mm screw from the underside of the plastic frame that holds the disc tray in place.
  3. HP 15-BA078DX Back Panel Replacement: 3 단계, 이미지 1/3 HP 15-BA078DX Back Panel Replacement: 3 단계, 이미지 2/3 HP 15-BA078DX Back Panel Replacement: 3 단계, 이미지 3/3
    • Remove the disk tray assembly by sliding it out from the side using the blue plastic opening tool.
  4. HP 15-BA078DX Back Panel Replacement, Back Panel: 4 단계, 이미지 1/1
    • Remove all of the remaining back panel screws with a #0 Phillips head screwdriver.
    • Remember to remove the two screws under the rubber feet.
  5. HP 15-BA078DX Back Panel Replacement: 5 단계, 이미지 1/3 HP 15-BA078DX Back Panel Replacement: 5 단계, 이미지 2/3 HP 15-BA078DX Back Panel Replacement: 5 단계, 이미지 3/3
    • Carefully use the blue plastic opening tool to pry the clam shell of the laptop apart.
    • You may need to flip the laptop over to unlatch all of the internal clips.
  6. HP 15-BA078DX Back Panel Replacement: 6 단계, 이미지 1/3 HP 15-BA078DX Back Panel Replacement: 6 단계, 이미지 2/3 HP 15-BA078DX Back Panel Replacement: 6 단계, 이미지 3/3
    • Carefully pull the shell of the computer apart.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Benjamin DosSantos Jr
회원 가입일: 03/20/18
469 평판
안내서 4개 작성하였습니다
UMass Dartmouth, Team S3-G4, Peak Spring 2018 UMass Dartmouth, Team S3-G4, Peak Spring 2018 회원
UMASSD-PEAK-S18S3G4
3 회원들
안내서 6개 작성하였습니다
댓글 한 개
Thank you so much! I know I am probably the only or one of the few people to write a comment for this specific laptop but I wanted to upgrade the RAM and HDD to SSD. Have a great day
Swag kitty - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 8
전체 시간: 700
