소개
This guide will detail the removal of the onboard Random Access Memory (RAM) modules that are installed in the laptop.
필요한 것
Unclip the two latches on the bottom of the laptop.
Slide the battery straight out while holding the clip open.
Using the Phillips #0 screwdriver, remove the 7.5mm screw from the underside of the plastic frame that holds the disc tray in place.
Remove all of the remaining back panel screws with a #0 Phillips head screwdriver.
다른 한 분이 해당 안내서를 완성하였습니다.
