주요 콘텐츠로 건너뛰기
HP 15-BA078DX Touchscreen Replacement
필요한 것
  1. HP 15-BA078DX Touchscreen Replacement, Battery: 1 단계, 이미지 1/3 HP 15-BA078DX Touchscreen Replacement, Battery: 1 단계, 이미지 2/3 HP 15-BA078DX Touchscreen Replacement, Battery: 1 단계, 이미지 3/3
    • Unclip the two latches on the bottom of the laptop.
    • Slide the battery straight out while holding the clip open.
  2. HP 15-BA078DX Touchscreen Replacement, Touchscreen: 2 단계, 이미지 1/3 HP 15-BA078DX Touchscreen Replacement, Touchscreen: 2 단계, 이미지 2/3 HP 15-BA078DX Touchscreen Replacement, Touchscreen: 2 단계, 이미지 3/3
    • Carefully use the blue plastic opening tool to remove the outer frame of the screen.
  3. HP 15-BA078DX Touchscreen Replacement: 3 단계, 이미지 1/3 HP 15-BA078DX Touchscreen Replacement: 3 단계, 이미지 2/3 HP 15-BA078DX Touchscreen Replacement: 3 단계, 이미지 3/3
    • Flip the laptop on its back.
    • Detach the bottom section of the screen frame from the laptop by using the black nylon spudger.
  4. HP 15-BA078DX Touchscreen Replacement: 4 단계, 이미지 1/1
    • Separate the frame from the screen.
  5. HP 15-BA078DX Touchscreen Replacement: 5 단계, 이미지 1/3 HP 15-BA078DX Touchscreen Replacement: 5 단계, 이미지 2/3 HP 15-BA078DX Touchscreen Replacement: 5 단계, 이미지 3/3
    • Using the Phillips #0 screwdriver, unscrew the 4 screws around the frame.
  6. HP 15-BA078DX Touchscreen Replacement: 6 단계, 이미지 1/3 HP 15-BA078DX Touchscreen Replacement: 6 단계, 이미지 2/3 HP 15-BA078DX Touchscreen Replacement: 6 단계, 이미지 3/3
    • Remove the touchscreen from the laptop.
    • Be careful not to damage the screen connector located at the bottom of the screen.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Matthew Moore
회원 가입일: 03/19/18
341 평판
안내서 1개 작성함
UMass Dartmouth, Team S3-G4, Peak Spring 2018 UMass Dartmouth, Team S3-G4, Peak Spring 2018 회원
UMASSD-PEAK-S18S3G4
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 8
전체 시간: 483
