주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP 15-R011DX Hard Drive Replacement
필요한 것
  1. HP 15-R011DX Hard Drive Replacement, Battery: 1 단계, 이미지 2개 중 1개 HP 15-R011DX Hard Drive Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Slide the lock mechanism on the left side of the laptop to the right.
  2. HP 15-R011DX Hard Drive Replacement: 2 단계, 이미지 1개 중 1개
    • While holding the right slide mechanism, remove the battery from the laptop.
    • The battery is not pictured here because it is missing from this particular device.
  3. HP 15-R011DX Hard Drive Replacement, How to Access the Internal Components of an HP 15-R011DX: 3 단계, 이미지 2개 중 1개 HP 15-R011DX Hard Drive Replacement, How to Access the Internal Components of an HP 15-R011DX: 3 단계, 이미지 2개 중 2개
    • Flip the laptop over to reveal screw locations.
    • Use a metal spudger to remove the two rear rubber feet. There are screws hidden underneath them.
  4. HP 15-R011DX Hard Drive Replacement: 4 단계, 이미지 2개 중 1개 HP 15-R011DX Hard Drive Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the twelve 5mm Phillips #1 screws on the back of the laptop.
  5. HP 15-R011DX Hard Drive Replacement: 5 단계, 이미지 2개 중 1개 HP 15-R011DX Hard Drive Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the DVD drive from the laptop.
    • Remove the two 3 mm Phillips #1 screws underneath the DVD drive.
  6. HP 15-R011DX Hard Drive Replacement: 6 단계, 이미지 3개 중 1개 HP 15-R011DX Hard Drive Replacement: 6 단계, 이미지 3개 중 2개 HP 15-R011DX Hard Drive Replacement: 6 단계, 이미지 3개 중 3개
    • Flip the laptop and open.
    • Detach the keyboard by prying it free from the laptop using a spudger.
    • Do not completely remove the keyboard yet. It is still attached by a ribbon cable.
    • Disconnect the keyboard ribbon cable.
  7. HP 15-R011DX Hard Drive Replacement: 7 단계, 이미지 2개 중 1개 HP 15-R011DX Hard Drive Replacement: 7 단계, 이미지 2개 중 2개
    • Disconnect the two narrow ribbon cables to the left of the keyboard connection.
    • Remove five 4 mm Phillips #1 screws from the metal tray for the keyboard.
    • Pry open the plastic casing using a spudger.
    • If struggling to remove the plastic case, check that all screws have been removed.
  8. HP 15-R011DX Hard Drive Replacement, Hard Drive: 8 단계, 이미지 1개 중 1개
    • Remove two 5 mm Phillips #1 screws located at the base of the hard drive.
  9. HP 15-R011DX Hard Drive Replacement: 9 단계, 이미지 2개 중 1개 HP 15-R011DX Hard Drive Replacement: 9 단계, 이미지 2개 중 2개
    • Pull the hard drive upwards and away from the laptop.
    • The hard drive should disconnect from its port on the motherboard as shown in the second image.
  10. HP 15-R011DX Hard Drive Replacement: 10 단계, 이미지 1개 중 1개
    • Flip the hard drive over.
    • Remove the two 4 mm Phillips #1 screws from the base of the hard drive.
    • Remove the mounting brace (silver bracket) from the hard drive.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Ethan Guillotte
회원 가입일: 03/20/19
517 평판
안내서 3개를 작성함
UMass Dartmouth, Team S2-G4, Bailey Spring 2019 UMass Dartmouth, Team S2-G4, Bailey Spring 2019 회원
UMASSD-BAILEY-S19S2G4
3 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 11
지난 30일: 48
전체 시간: 1,788
