주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP 15-R011DX RAM (Random Access Memory) Replacement
필요한 것
  1. HP 15-R011DX RAM (Random Access Memory) Replacement, Battery: 1 단계, 이미지 2개 중 1개 HP 15-R011DX RAM (Random Access Memory) Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Slide the lock mechanism on the left side of the laptop to the right.
  2. HP 15-R011DX RAM (Random Access Memory) Replacement: 2 단계, 이미지 1개 중 1개
    • While holding the right slide mechanism, remove the battery from the laptop.
    • The battery is not pictured here because it is missing from this particular device.
  3. HP 15-R011DX RAM (Random Access Memory) Replacement, How to Access the Internal Components of an HP 15-R011DX: 3 단계, 이미지 2개 중 1개 HP 15-R011DX RAM (Random Access Memory) Replacement, How to Access the Internal Components of an HP 15-R011DX: 3 단계, 이미지 2개 중 2개
    • Flip the laptop over to reveal screw locations.
    • Use a metal spudger to remove the two rear rubber feet. There are screws hidden underneath them.
  4. HP 15-R011DX RAM (Random Access Memory) Replacement: 4 단계, 이미지 2개 중 1개 HP 15-R011DX RAM (Random Access Memory) Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the twelve 5mm Phillips #1 screws on the back of the laptop.
  5. HP 15-R011DX RAM (Random Access Memory) Replacement: 5 단계, 이미지 2개 중 1개 HP 15-R011DX RAM (Random Access Memory) Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the DVD drive from the laptop.
    • Remove the two 3 mm Phillips #1 screws underneath the DVD drive.
  6. HP 15-R011DX RAM (Random Access Memory) Replacement: 6 단계, 이미지 3개 중 1개 HP 15-R011DX RAM (Random Access Memory) Replacement: 6 단계, 이미지 3개 중 2개 HP 15-R011DX RAM (Random Access Memory) Replacement: 6 단계, 이미지 3개 중 3개
    • Flip the laptop and open.
    • Detach the keyboard by prying it free from the laptop using a spudger.
    • Do not completely remove the keyboard yet. It is still attached by a ribbon cable.
    • Disconnect the keyboard ribbon cable.
  7. HP 15-R011DX RAM (Random Access Memory) Replacement: 7 단계, 이미지 2개 중 1개 HP 15-R011DX RAM (Random Access Memory) Replacement: 7 단계, 이미지 2개 중 2개
    • Disconnect the two narrow ribbon cables to the left of the keyboard connection.
    • Remove five 4 mm Phillips #1 screws from the metal tray for the keyboard.
    • Pry open the plastic casing using a spudger.
    • If struggling to remove the plastic case, check that all screws have been removed.
  8. HP 15-R011DX RAM (Random Access Memory) Replacement, Hard Drive: 8 단계, 이미지 1개 중 1개
    • Remove two 5 mm Phillips #1 screws located at the base of the hard drive.
  9. HP 15-R011DX RAM (Random Access Memory) Replacement: 9 단계, 이미지 2개 중 1개 HP 15-R011DX RAM (Random Access Memory) Replacement: 9 단계, 이미지 2개 중 2개
    • Pull the hard drive upwards and away from the laptop.
    • The hard drive should disconnect from its port on the motherboard as shown in the second image.
  10. HP 15-R011DX RAM (Random Access Memory) Replacement: 10 단계, 이미지 1개 중 1개
    • Flip the hard drive over.
    • Remove the two 4 mm Phillips #1 screws from the base of the hard drive.
    • Remove the mounting brace (silver bracket) from the hard drive.
  11. HP 15-R011DX RAM (Random Access Memory) Replacement, Motherboard: 11 단계, 이미지 2개 중 1개 HP 15-R011DX RAM (Random Access Memory) Replacement, Motherboard: 11 단계, 이미지 2개 중 2개
    • Remove the remaining two 5 mm Philips #1 screws from the motherboard.
  12. HP 15-R011DX RAM (Random Access Memory) Replacement: 12 단계, 이미지 1개 중 1개
    • Remove the tape from the display connector attached to the motherboard.
    • Disconnect the display connector from the motherboard.
  13. HP 15-R011DX RAM (Random Access Memory) Replacement: 13 단계, 이미지 1개 중 1개
    • Remove one 4 mm Phillips #1 screw from the wireless chip.
    • Remove the wireless chip from the motherboard.
  14. HP 15-R011DX RAM (Random Access Memory) Replacement: 14 단계, 이미지 1개 중 1개
    • Remove two 5 mm Phillips #1 screws from the USB component connected to the motherboard.
    • Lift the USB component until the band connecting it to the motherboard lifts off of the laptop.
  15. HP 15-R011DX RAM (Random Access Memory) Replacement: 15 단계, 이미지 1개 중 1개
    • Slowly lift the motherboard out of the computer.
    • Be sure that the I/O ports on the left side of the motherboard are not stuck on the laptop frame.
    • Disconnect the power connector from the motherboard as shown in the image.
  16. HP 15-R011DX RAM (Random Access Memory) Replacement, RAM (Random Access Memory): 16 단계, 이미지 1개 중 1개
    • Locate the RAM drive on the underside of the motherboard.
  17. HP 15-R011DX RAM (Random Access Memory) Replacement: 17 단계, 이미지 2개 중 1개 HP 15-R011DX RAM (Random Access Memory) Replacement: 17 단계, 이미지 2개 중 2개
    • Push the locking tabs outward to release the RAM chip from the motherboard.
  18. HP 15-R011DX RAM (Random Access Memory) Replacement: 18 단계, 이미지 1개 중 1개
    • Remove the RAM chip by pulling the drive from the connectors.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Joshua Brockman
회원 가입일: 03/25/19
368 평판
안내서 2개를 작성함
UMass Dartmouth, Team S2-G4, Bailey Spring 2019 UMass Dartmouth, Team S2-G4, Bailey Spring 2019 회원
UMASSD-BAILEY-S19S2G4
3 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 31
전체 시간: 1,337
