주요 콘텐츠로 건너뛰기
HP 15-ac121dx Back Panel Replacement
필요한 것
  1. HP 15-ac121dx Back Panel Replacement, Battery: 1 단계, 이미지 1/1
    • Remove all external devices from the computer.
    • Remove the charging cord from the computer.
  2. HP 15-ac121dx Back Panel Replacement: 2 단계, 이미지 1/1
    • Turn off the computer by holding the power button.
  3. HP 15-ac121dx Back Panel Replacement: 3 단계, 이미지 1/2 HP 15-ac121dx Back Panel Replacement: 3 단계, 이미지 2/2
    • To remove the battery, slide the left slider on the back to the unlocked position.
  4. HP 15-ac121dx Back Panel Replacement: 4 단계, 이미지 1/2 HP 15-ac121dx Back Panel Replacement: 4 단계, 이미지 2/2
    • Push the right slider inwards.
    • Remove the battery out by pulling straight out and to the right.
  5. HP 15-ac121dx Back Panel Replacement, Back Panel: 5 단계, 이미지 1/2 HP 15-ac121dx Back Panel Replacement, Back Panel: 5 단계, 이미지 2/2
    • Place the laptop with the back panel facing up and the battery compartment facing away from you.
    • Using a spudger, carefully remove the rubber feet on both sides of the battery compartment.
  6. HP 15-ac121dx Back Panel Replacement: 6 단계, 이미지 1/1
    • Using a Phillips #000 screwdriver, remover the ten 7mm screws on the back panel.
    • Using the same screwdriver, remove the two 5mm Phillips #000 screws on both sides of the battery compartment.
  7. HP 15-ac121dx Back Panel Replacement: 7 단계, 이미지 1/1
    • With the same orientation as the previous step, locate the bottom left corner.
    • Using a plastic opening tool, carefully pry off and remove the back panel.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Daniel Adams
회원 가입일: 09/30/19
229 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 13
전체 시간: 960
