주요 콘텐츠로 건너뛰기
HP 15-ac121dx CD Compartment Replacement
필요한 것
  1. HP 15-ac121dx CD Compartment Replacement, Battery: 1 단계, 이미지 1/1
    • Remove all external devices from the computer.
    • Remove the charging cord from the computer.
  2. HP 15-ac121dx CD Compartment Replacement: 2 단계, 이미지 1/1
    • Turn off the computer by holding the power button.
  3. HP 15-ac121dx CD Compartment Replacement: 3 단계, 이미지 1/2 HP 15-ac121dx CD Compartment Replacement: 3 단계, 이미지 2/2
    • To remove the battery, slide the left slider on the back to the unlocked position.
  4. HP 15-ac121dx CD Compartment Replacement: 4 단계, 이미지 1/2 HP 15-ac121dx CD Compartment Replacement: 4 단계, 이미지 2/2
    • Push the right slider inwards.
    • Remove the battery out by pulling straight out and to the right.
  5. HP 15-ac121dx CD Compartment Replacement, Back Panel: 5 단계, 이미지 1/3 HP 15-ac121dx CD Compartment Replacement, Back Panel: 5 단계, 이미지 2/3 HP 15-ac121dx CD Compartment Replacement, Back Panel: 5 단계, 이미지 3/3
    • Locate the CD Compartment panel and gently slide it out.
  6. HP 15-ac121dx CD Compartment Replacement: 6 단계, 이미지 1/1
    • Remove the back of the laptop by unscrewing the screws shown.
    • Also remove the other 5 Phillips screws lining the back cover.
  7. HP 15-ac121dx CD Compartment Replacement: 7 단계, 이미지 1/3 HP 15-ac121dx CD Compartment Replacement: 7 단계, 이미지 2/3 HP 15-ac121dx CD Compartment Replacement: 7 단계, 이미지 3/3
    • Using the prying tool, wedge it underneath the back of the laptop and do the same all around until the back comes off.
    • Dont forget to unscrew 2 screws under 2 plastic tabs (one on each hing). The lid will not come off without them being removed!
  8. HP 15-ac121dx CD Compartment Replacement, CD Compartment: 8 단계, 이미지 1/3 HP 15-ac121dx CD Compartment Replacement, CD Compartment: 8 단계, 이미지 2/3 HP 15-ac121dx CD Compartment Replacement, CD Compartment: 8 단계, 이미지 3/3
    • Locate the CD Compartment as shown and gently slide it out.
결론
Replace CD compartment. To reassemble your device, follow these instructions in reverse order.
다른 4명이 해당 안내서를 완성하였습니다.
Ashton Martin
회원 가입일: 01/30/18
459 평판
안내서 2개 작성하였습니다
Baylor, Team S1-G2, Johnson Spring 2018 Baylor, Team S1-G2, Johnson Spring 2018 회원
BU-JOHNSON-S18S1G2
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 8
전체 시간: 391
