주요 콘텐츠로 건너뛰기
HP 15-ac121dx Motherboard Replacement
필요한 것
  1. HP 15-ac121dx Motherboard Replacement, Battery: 1 단계, 이미지 1/1
    • Remove all external devices from the computer.
    • Remove the charging cord from the computer.
  2. HP 15-ac121dx Motherboard Replacement: 2 단계, 이미지 1/1
    • Turn off the computer by holding the power button.
  3. HP 15-ac121dx Motherboard Replacement: 3 단계, 이미지 1/2 HP 15-ac121dx Motherboard Replacement: 3 단계, 이미지 2/2
    • To remove the battery, slide the left slider on the back to the unlocked position.
  4. HP 15-ac121dx Motherboard Replacement: 4 단계, 이미지 1/2 HP 15-ac121dx Motherboard Replacement: 4 단계, 이미지 2/2
    • Push the right slider inwards.
    • Remove the battery out by pulling straight out and to the right.
  5. HP 15-ac121dx Motherboard Replacement, Back Panel: 5 단계, 이미지 1/3 HP 15-ac121dx Motherboard Replacement, Back Panel: 5 단계, 이미지 2/3 HP 15-ac121dx Motherboard Replacement, Back Panel: 5 단계, 이미지 3/3
    • Locate the CD Compartment panel and gently slide it out.
  6. HP 15-ac121dx Motherboard Replacement: 6 단계, 이미지 1/1
    • Remove the back of the laptop by unscrewing the screws shown.
    • Also remove the other 5 Phillips screws lining the back cover.
  7. HP 15-ac121dx Motherboard Replacement: 7 단계, 이미지 1/3 HP 15-ac121dx Motherboard Replacement: 7 단계, 이미지 2/3 HP 15-ac121dx Motherboard Replacement: 7 단계, 이미지 3/3
    • Using the prying tool, wedge it underneath the back of the laptop and do the same all around until the back comes off.
    • Dont forget to unscrew 2 screws under 2 plastic tabs (one on each hing). The lid will not come off without them being removed!
  8. HP 15-ac121dx Motherboard Replacement, Fan: 8 단계, 이미지 1/3 HP 15-ac121dx Motherboard Replacement, Fan: 8 단계, 이미지 2/3 HP 15-ac121dx Motherboard Replacement, Fan: 8 단계, 이미지 3/3
    • Locate the Fan as shown.
    • Pull out the black cable, with four wires attached from its port.
  9. HP 15-ac121dx Motherboard Replacement: 9 단계, 이미지 1/2 HP 15-ac121dx Motherboard Replacement: 9 단계, 이미지 2/2
    • Pull out the white cable wire from its port.
    • Unscrew the two black Phillips screws holding in the fan.
  10. HP 15-ac121dx Motherboard Replacement: 10 단계, 이미지 1/2 HP 15-ac121dx Motherboard Replacement: 10 단계, 이미지 2/2
    • Remove fan.
    • Unscrew the two screws holding in the fan.
  11. HP 15-ac121dx Motherboard Replacement, CD Compartment: 11 단계, 이미지 1/3 HP 15-ac121dx Motherboard Replacement, CD Compartment: 11 단계, 이미지 2/3 HP 15-ac121dx Motherboard Replacement, CD Compartment: 11 단계, 이미지 3/3
    • Locate the CD Compartment as shown and gently slide it out.
  12. HP 15-ac121dx Motherboard Replacement, Motherboard: 12 단계, 이미지 1/1
    • Remove the TEN 3mm screws.
    • Remove the ONE 9mm screw.
  13. HP 15-ac121dx Motherboard Replacement: 13 단계, 이미지 1/2 HP 15-ac121dx Motherboard Replacement: 13 단계, 이미지 2/2
    • Locate the four ribbon clips.
    • Lift the grey part of the ribbon clips.
    • Pull the ribbon cable out and repeat this step for all four ribbon cables.
    • Also use a spudger and release the TWO cables attaching the hard drive to the motherboard. Another ribbon cable is located where the fan was sitting.
  14. HP 15-ac121dx Motherboard Replacement: 14 단계, 이미지 1/2 HP 15-ac121dx Motherboard Replacement: 14 단계, 이미지 2/2
    • Pull out the white cable (contains red and white cable attached to a black support) with wires from its port.
  15. HP 15-ac121dx Motherboard Replacement: 15 단계, 이미지 1/1
    • Remove the motherboard.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Onose Aigbe
회원 가입일: 01/30/18
390 평판
안내서 3개 작성하였습니다
Baylor, Team S1-G2, Johnson Spring 2018 Baylor, Team S1-G2, Johnson Spring 2018 회원
BU-JOHNSON-S18S1G2
3 회원들
안내서 6개 작성하였습니다
댓글 한 개
Pls can the motherboard of HP - 15 ac-250g5 replacethe board of HP 15 ac-121dx since they have the same body structure.
Emeka Jeffrey - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 14
전체 시간: 1,408
